メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年9月25日に発売されたSamsung Galaxy Noteシリーズの第3世代ファブレットです。モデル番号N9005で識別できます。
note 3 turns off by itself
my note 3 sm-n900 turns off by itself frequently , (4-5 times a day) and does not power on unless i remove the battery and replace it back, tried another battery but the same problem persists, looks like a loose contact or something like that, it usually happens in my jeans pockets , any help would be highly appreciated, thank you !
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 25
5 件のコメント
i have a problem with my note 3 if i turn it on ,after few seconds it just turns itself off and I`ve tried to hard reset it but it is not giving me time to run the operation because it just turn off for just few seconds the it turns itself off
さんによる
and during that short time whilst it is on it gets to be hot at a position where the memory card and sim are inserted
さんによる
Me to I have a problem with my galaxy note 3 while I am playing games and using facebook I solve this problem by taking out battery and replace but he always shutdown himself .Please excuse me if I was something wrong in grammar.
さんによる
My galaxy note 3 turns off and on continuously by itself and it's like entering in an eternal cycle of turning on and of until i not remove and place again the battery and then after i switch on it starts again the same. When i plug charging cable every things runs fine, except when i turn it off and remove the charging cable, then the whole epopee starts again . New battery - the same. Safe mode - the same.
さんによる
My galaxy note 3 continuously turns off and on by itself. To stop that, I have to remove the battery. When I put the battery back in, the cycle (on then off) starts again. I replaced the battery last year because the original one died.
The phone works while plugged in to be charged.
さんによる
コメントを追加
15件の回答
最も参考になった回答
Sounds like a possible loose connection somewhere . Best bet is to open it up and check all connectors and re tighten the screws. I have seen this issue on IPhone 4s before and it was a short because of a bad power cable.It might also be some sort of software issue maybe try restoring.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I would bet that this is a power button repair. Most of the time this happens as the solder becomes unstable where the power button is soldered to the logic board.
Here is an image of a power button repair
画像
Here is a link to our power button repair video. https://www.youtube.com/watch?v=qXqPqAsf...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If it is the problem of power button , how the phone become power on again after remove the battery and put it back ??
さんによる
コメントを追加
Well I have also had this problem on my note 3 and good luck to you I have a fix for you all you got to do it take your memory card out and it works like new I think this is a problem maybe the memory card gets defective somehow but I just replaced mine and it works just fine I hope this fixed your problem
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Did you start getting a pull down about the SD card being removed even if it wasn't?
さんによる
I could not turn off the phone even remove the battery. I googled and found this comment. I removed a memory card .... then miracle happened! Not it is working again! Thank you just me.
さんによる
コメントを追加
Had same problem when first got my Note 3 and 2 extra batteries. After a long search found the solution. If you give a tap on the top of the phone and it turns off its the battery. I put a thin pice of plastic and glued it on the bottom of the battery and that did it. You can use a business card cut it to size.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This fixed my problem...... thanks for posting. Ray
さんによる
コメントを追加
I have the same problem as described, but usually my phone turns off when doing some processor intensive task like snapchat filters, pokemon go list browsing etc, It doesnt turns on until I remove the battery but it turns on if you put the phone in charging.
I have also noticed that If the phone is charging this issue doesn't happen.
Strange issue, I still havent got any solution for this.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
Yep you discredit it perfectly I have the same problem in my note 3 I think it's a problem in the phone from where it's made mine is vietnam
さんによる
I have found the solution to my issue, it was due to a faulty battery, it was my 2nd battery just 5 months old causing the issue, I bought it from samsung store so I had 6 months warranty, and got it replaced immediately.
The issue is solved now
さんによる
さんによる
Sachin, this describes the issue I'm having exactly. What custom ROMs have you used over the past year?
さんによる
No... I do not use any custom ROM, stock ROM since the beginning
さんによる
2件以上のコメントを表示
コメントを追加
sir,
since last few days i am observing that as soon as i am keeping my cell in my jeans pocket it gets automatically off and then if i try to restart it,it won't
then i need to take out the battery and again put in it amd them restart it..sometimes it restarted at the forst time but sometimes it wont and i need to do this 5-6 times and if it gets restarted and then i put back cover then it again went out and cell then again automatically goes off..and now this problem is increasing
may i knw d reason nd solution of ds problem plz
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The same thing is happening to me....
さんによる
コメントを追加
Hey there, I tried this solution as I also experienced the same issue you are describing. The movement of being in your pocket can cause the battery terminals to become glazed, try using a pin or emery board etc, to scratch away the gunk that builds on the terminals, like in this video, it seems to have resolved the problem for me. Hope it helps!
https://www.youtube.com/watch?v=1Rm0L_eh...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No it went off once without coming back again
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This fixed my problem...... thank you very much for sharing...... Ray
さんによる
コメントを追加
1 is That It Has Dust In Your Phone Powebutton ect.
2 There Might Be Too Many Apps Or Vides, Photos
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same issue with my note 3. But sometimes when I turn my on, a rainbow of colors comes up like a glitch and it won't turn on. My screen is fine and I have had it taken in and of course it wouldn't do it then. But it only started happening after the update that came out in early to mid January of this year. I was convinced it was either the phone or the update.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I changed the battery and the problem is gone. A bad charger caused battery failure
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My note 3 turned off by itself and i have not been able to switch it on for 3 days now. When I charge it, it doesn't display anything or bring out charging information but after a while the rear camera place begins to get hot.
P. S: switching off by itself has always happened before but it comes right back up after I remove the battery and put it back.
Done that now but nothing is working. I've even tried removing my sim and memory card
さんによる
コメントを追加
The Galaxy Note 3 welcome page doesn't even show
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This saldly sounds like a dead EMMC, take it to a service store, but if this is the case you need to change your phone, ( or buy a completely new mother board)
さんによる
コメントを追加
Hello Everyone
i Have Faced This Problem
This Is No Firmware(software) And EFS Problem, This Os Hardware PCB Problem
When Me Try All Of Tricks Me Found solution Temprory But Solve The Problem
and Not A Power Swotch Or Mem. Card Fault
The Power Ic REBALL needed For Permentent Solution Or Replace With New
And Without Replace or reball I Have Solve This Peoblem
1. Remove top Side 3 Scru By Scru driver
And Use Handsend
its May Delay of the time shutdown
my expiroance when me using without scruw its fix some time gose $@$* down like 15 to 20 day after and its 1 time but no longer shutdown in the month 1 to 2 time just shutdown
try this solution
and 2nd some of the mobile not power ic fault its caused by front camera and proxy sensor fault
so try 1 method if not sucsses try 2nd method Good Luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sounds to me as if you've got display sleep function on auto. To fix this, simply place your phone in a tupperware, then place it in the microwave. 20 seconds is enough to hardwire the original settings. Good luck!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
And then go to the recycle bin and put it in, and wait for the fortune.
さんによる
コメントを追加
My battery was low so I bought one on Ebay. After about a year phone started to turn off and on and would now hold a charge. Would take battery out and back in and it would work for a while but then the problem got worse. It would show battery was full but then it would completely discharge and start rebooting. I finally bought another battery and the problem solved. I guess the 2nd battery was defective . Bought new one at Batteries plus . They guarantee the battery for life as long as your phone is working correctly
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sameer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 43,029
