メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Inspiron M5010 パーソナルノートパソコン。15.6インチスクリーン、ピンクのカバー、2010年11月3日発売。
8 beeps with full black screen
i have tried few ideas :
1. remove battery & power plug then push power button for 1 min.
2. remove ram and insert it again
3. press D+Power button
4. fn+ Power button.
but none of this work...
have you any idea accept this...??
what is the reason for this 8 beep & black screen??
Update
i tried that option with HDMI cable Fn+F1 keys to us the external monitor. .. but it still beeps 8 time... and i think its not detecting HDMI... what should i do..?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
after lot time switch on off... finally it started once and thn i restore BIOS settings and format d oprating system... thn check in diagnostics test... but everything is alright... but still my problm is not solved after few hours it as usual started 8 beeps and black screen when i switch it on... i could not caught the problem...
さんによる
I have the same problem but when I use the external monitor the laptops works fine. I tested the LCD screen with a different laptop and the screen works fine. so what could be the cause of the beeping and black screen?
さんによる
コメントを追加
2件の回答
ベストアンサー
The 8 beeps that you are receiving from the computer would indicate an issue with the LCD screen. I would suggest you to connect an external monitor with the system and press the Fn+F1 keys to us the external monitor.
If the external monitor works then i would recommend running the LCD Built-in Diagnostics which the instructions can be found here - http://www.dell.com/support/article/us/e...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
what i found was when dissassemble screen that the cable somehow came loose. just plug back in correctly.( use scotchtape or other ) to hold secure.. problem solved
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
apurvajimmy777 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 4,181
