left hinge frozen ;pops out of top
Hinge IS frozen ;it pops outta the case top.EEK This IS not GOOD.
power pc G4 /867mhz.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
it's almost normal that the left inge breaks (ok, i have one with a broken right hinge, but the left one breaks more often).
read more about it in the g4 troubleshooting
don't think to hard about changing the hinge - it's "easier" to change the complete display assembly
このアンサーは役に立ちましたか?
+ nice link
This IS at its heart a sleeve& pin hinge.you have to align the 2 nipples on the sleeve with the slot on the sleeve,drive it out /w a Brad.file off the nipples and use sandpaper to reduce the pin diameter untill it works.reassemble & your in buisness.The pin freezes ;then breaks.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 1,090
