メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Acer Aspire E1-571ノートパソコンの修理とトラブルシューティングに関するヘルプ。
Sensitive usb sockets on right hand side
The usb sockets on the right side of my laptop don't work right. If I've something plugged in either usbs on the right side only they stop working/disconnect
If it's a mouse I hear the same sound as I'd hear if I were to unplug it. Then it will stop working. 2 seconds later if I stop touching it I'll hear the sound that happens when I connect it and it works again
I don't really wanna strip it down till I know more about it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
最も参考になった回答
Hi,
Try to reinstall the USB drivers. Go into "Device manager", "Universal Serial Bus controllers" and uninstall all USB Hub drivers, Intel Chipset USB controllers and USB 3.0 controllers. Then restart the Windows.
Regards.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had this problem after I accidentally knocked the port whilst it had a USB plug in it. I think it's mechanical damage to the solder joints or socket PCB. Bad news, you'll have to pop that board out and resolder them or replace it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There may be problem with your USB driver. so you need to uninstall the USB driver from your computer and then reinstall it .
If it is still not working then you need to clean your USB port then it will start working fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
williamsf1driver さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 13
今までの合計 1,898
