メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Problems installing a new HD
I have a late 2009 15" MBP.
My original HD crapped out and I replaced it with a Hitachi Travelstar 750gb / 7200 RPM.
Using Snow Leopard install disc I had troubles formatting the new HD and could install 10.6 when HD was internal.
As a USB HD, I was able to format HD using another MBP, but when I reinstalled the HD in the 2009 MBP, the Snow Leopard install would quit after a few minutes.
However when the HD was hooked up externally to the 2009, the Snow Leopard installed no problem.
Computer performs using new HD externally. Should I expect problems if I install internally.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Can you give us the last four digits of your serial number so we can verify your system. Also can you give us the exact make & model of your HD you are trying to install.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Probably the HD cable... have a spare on hand when you install the new HD.
FWIW You don't have to completely replace all the reassembly screws. Be careful (starting on a hard surface) to test and see if it will boot. If it doesn't you can swap the HD cable without a lot of extra time and work.
If this answer is acceptable please remember to return and mark it accepted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
chris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 242
