メインコンテンツにスキップ
10 Cup Coffee Maker, 900W, identified by KF440. Made in Germany.
3回答 すべてを表示
Why does the coffee maker drip when I move the pot?
Sometimes I try to pour a cup of coffee while the coffee maker is still brewing. In the past when I’ve done this, the machine will stop brewing while I poured, but now it keeps brewing and drips onto the hot plate.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
If you pull out the filter holder and look at the bottom you will see a rubber ball on a paddle stick which is the stopper to prevent the coffee from leaking when you pull the carafe away.
I've had to clean mine a few times as the grains of coffee can sometimes prevent the sealing of the opening. If the rubber is hard it maybe time to replace the part.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Good tips, Dan. As said above, there is a ball and spring mechanism that is part of the filter basket. If you still experience the problem after you clean it, they do offer new filter baskets online that come with the ball and spring mechanism. Here is a link to the troubleshooting page that has a guide which details how to replace the filter basket and also has links to websites that offer the filter basket replacement part.
Braun Aromaster KF 440 Troubleshooting
This could also occur due to overflowing. If too much water was poured into the reservoir, the filter basket could overflow if the carafe is removed for too long.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kelly さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 42
今までの合計 7,531
