Graphics card is bad.
I have a MacBook Pro 15" (Model A1211) 2.16 GHz. Just need to know if the Graphics card is located on the logic board? if not, where is it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes it is soldered to the logic board.
Re-flow is a "shade tree fix" it may work, may not work. If it works it may work for just a little while or for quite a while.
A DIY re-flow is risky - one person here recently baked a logic board in an oven and had components fall off! Since they had no pictures they had no clue where the parts came off.
A "professional" repair or re-flow from a service on e-bay is a different animal... but only you can do the cost analysis .
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 443
3 件のコメント
This model did not have the nVidia GPU. GPU failures are very rare on your machine. Have you tried using an external monitor?
mayer さんによる
I have not tried an external monitor. When I start up my MacBook I can't even see my user login. Will I be able to still get the computer to display on an external monitor if I can't get past login?
Tim Machgan さんによる
Tried external monitor. All I have is blue screen on both laptop and monitor. Disconnected external monitor and now all I get on laptop is blue screen on start up . Any advice?
Tim Machgan さんによる
