メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2009年に発売された、InspironラインとXPSラインの中間に位置する、一般消費者向けデスクトップシリーズ。
Random errors, but how are they connected?
I have multiple things that my Dell Studio 17 will do that all seem to happen at the same time, but don't seem to be related. Here is what happens:
  • Flash player stops working and crashes browser
  • Bluetooth devices will not connect
  • Skype crashes
  • iTunes will not open
I have no idea how any of these would be connected, but the all seem to happen at the same time. I am going to reinstall the OS soon, but I just would like to know for curiosity's sake.
Thanks for your help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Andrew I'm going to make a guess that you are probably using some form of Windows. The most likely common cause I can think of would be a shared dll that has become corrupted somehow. I believe your planned OS reinstall should clear your problem by replacing the dll. To be on the safe side I would install the programs one at a time and use them for a day or so before adding the next. That could help you find what is causing the dll problem. Hope this helps you. Ralph
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
One easy attempt to repair it is by using system restore. look it up as it's different to access between operating systems. All you need to do is choose a restore point on which the computer was working fine; really easy. good luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Andrew Guenther さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 1,127
