Flash de-synchronized from camera trigger
Flash light seems to be de-synchronized from the trigger of the camera.
When taking a picture in dark, the flash activates one or two seconds too late. Thanks for help.
You might have a bad flash capacitor, in some cameras it is used to build and store a charge that is released to power the flash. I'll have to look into this further.
このアンサーは役に立ちましたか?
You may also want to check the settings, or select the "factory reset" option, if it has one.
I think its more then that... unless you shoot the moment after you turn on the camera. The fact that it shoots means that the capacitor works, its the trigger that shorts it (to flash) is.. delayed.
This question has been around forever, and I cant seem to find anything documenting, nevermind fixing it, anywhere online.
did you find an answer? seems as if you're on the correct path...thank you
過去 24時間: 0
過去 7 日: 4
過去 30 日: 28
今までの合計 1,531
1件のコメント
Excellent question. I have looked and looked around, but cant seem to find anything on that.
Majesty さんによる 共有
