メインコンテンツにスキップ
The Fosera Scandle 200 is a solar powered device that can be used as a lantern and/or a charging station for electronic devices.
2回答 すべてを表示
Why is my device not holding a charge?
I've had my device for a while now. Lately, it only works when plugged in.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
If your device is not holding a charge after a full charging cycle then your battery has likely reached the end of its lifespan. Rechargeable Lithium-ion batteries have a limit for the number of charging cycles they can go through, and as this limit is approached the battery will exhibit much a much lower capacity.
See heading "My device only works when the solar panel is attached" in the troubleshooting page at:
Fosera Scandle 200 Troubleshooting
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Vincent C さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 331
