Why is my device not holding a charge?
I've had my device for a while now. Lately, it only works when plugged in.
If your device is not holding a charge after a full charging cycle then your battery has likely reached the end of its lifespan. Rechargeable Lithium-ion batteries have a limit for the number of charging cycles they can go through, and as this limit is approached the battery will exhibit much a much lower capacity.
See heading "My device only works when the solar panel is attached" in the troubleshooting page at:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 235
