メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Replacing Cell Antenna (searching...)
My 5S got stuck in a searching mode where he can't connect to the Sprint network. It was working fine until afternoon yesterday suddenly stopped working. When it was on Wi-Fi I am able to use iMessage and use apps like Safari and access the Internet, but I still can't make or receive calls and I also can't send text messages.
I tried doing reset network settings, and even it all out restore, with no luck. I've also tried ejecting the Sim card and reinserting it. I still have the same problem.
I googled around a little bit and found this website suggesting that the antenna and it may need to be fixed on the iPhone five model. The parts on the iPhone 5s, but I can't find any type of repair list it for the cell antenna.
Is this possible? I don't see any type of package on iFixit.
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
コメントを追加
17件の回答
最も参考になった回答
The problem here could be a faulty baseband IC, the phone usually goes into "searching" with this fault and is unable to find a mobile network, to further check whether this is the fault, more often than not the modem firmware number (which you can find in settings > about) , is blank
To fix this problem, it can be done by reflowing the IC, but as with any reflow, the fix is never guaranteed to be a permanent 1, the best fix is to have it removed and reballed (new solder applied)
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
This post is three years old.
さんによる
My comment was in reply to Anwar who's question was a few weeks ago and was unanswered,. you've marked my comment down ??, you absolute twonk !!
さんによる
Does not matter it is old - just helped me a lot. Indeed my Iphone 5s is stuck on "Searching" and the Modem Firmware is blank. Now I just have to figure out what is "baseband IC" and how to fix it... Thanks!
さんによる
コメントを追加
Don't replace the antenna, this is a main board problem, replacing the antennas won't help
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
Can the main board be replaced, or is it bricked now?
さんによる
Don't replace the main board, it is not economical. Repair it.
As long as the baseband chip is intact, it can be economically repaired.
さんによる
How would this be done? I don't see a guide to repair the logic board. How can I tell if it's intact?
さんによる
how can it be repaired?
さんによる
ever get this sorted? I have exactly the same problem
さんによる
2件以上のコメントを表示
コメントを追加
Hello have you tried another sim it's possable the sun could be the problem.
Anyway if another sim is having the same issue then you need to replace antenna it is located on the dock connector so you will need to replace it.
iPhone 5sのLightningコネクターの交換
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
So you're suggesting to replace the lightning connector and this will fix the problem, or is the cellular antenna another part? Thanks.
さんによる
There are 3 antennas in the iPhone 5s. They can't fail at the same time. So it must be something wrong with the main board. Check in the system settings that you can still read IMEI and ICCID, if not, the baseband isn't working, which means the phone is mostly likely not worth repairing.
さんによる
Yes replace the lighting port as the antenna is located on it
さんによる
I can't boot the phone at all. It's stuck in recovery mode and when I try to restore it via iTunes it fails after about 45 minutes with an Error 3 code. The install log suggests that the Baseband failed.
さんによる
My baseband is working and I can read IMEI and ICCID. However my reception is still spotty. Should I replace the lightning connect?
さんによる
コメントを追加
I have an answer just throw that piece o $@$* from sprint down an elevator shaft and all problems solved!! Becauae SPRINT SUXXXX
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Poop ,,,$@$* this thing wont let me say $@$* haaa
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
did u try puttin it in rice
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
is it basmathi?
さんによる
@valentinic86 yos very much
さんによる
Are you making iPhone paella?
さんによる
nopez dhall may work better
さんによる
Quoting Tom Holland from Spiderman: Far From Home... "What just happened?!" 8-/
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Main board problem. Replacing the charging flex will resolve nothing. As another has already pointed out there are multiple attanie and the likelyhood of simultaneous failure is too slim. Moisture commonly causes this failure. Especially if it is located on the underneath side of the Sim on the main board. Try placing a different cellular provider's sim a lot of times certain frequencies are damaged at the end of the day your sprint phone is only suited for sprint network usage. Goodluck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try resetting the phone, it might help, had same issue in the past. replacing the antenna will not help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I got 5c, it's keep searching, no bet work for past 13 hours, what do I need to do. I did all resetting but doesn't working.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have an iPhone 5S I water on it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try using R-SIM 11+ or replace Docking cable
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
For me, this link was very helpful to solve the problem (No Network and No Firmware )
Synch your iPhone 5s with Mac's iTunes and at iTunes, use "restore iphone" button. https://discussions.apple.com/thread/799...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try to put some hot air on the device, make sure to spread the air evenly around the dock and lightning port area, also try to put some at the top by the wifi and bluetooth antennas just to be a little bit thorough with it so then nothing goes untouched. if that does not work try leaving the hot air on the sim reader for about 20-30s and check if it works again, if it does then good but if it does not then that's fine. the next step to try would be to put it in either an Ultrasonic Cleaner or a bath of Alcohol what this will do is clean the logic board of any impurities and make it look nice and clean also ;)
If you have any troubles with this, feel free to comment on this post ;)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i phone 5s serching essu
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Put it in rice.
Add some chicken and salad with balsamic vinegar. It’s a classic Filipino dish.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My issue is almost the same except it’s my wifi. I cannot log into the wifi @home. Other iPhones can android and apple. My iPad is also working on the home wifi. I’ve done everything (I.e.reset back to factory, update, dfu, restart dsl router,).
I was able to get onto &log in use the “unhelpful”istore in the mall.
what gives?
Please Help!
Thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 10
今までの合計 57,698
