メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年5月発売。ディスプレイ:1200 x 1920ピクセル、10.1インチ。チップセット:Qualcomm Snapdragon APQ8064、 CPU:クアッドコア 1.5 GHz Krait、GPU:Adreno 320。メモリ:16/32 GB、2 GB RAM。Android OS、v4.1.2(Jelly Bean)、v4.4.2(KitKat)にアップグレード可能。
screen broken but working
my tablet z touch screen broken, i want any professional guide to change a new screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
コメントを追加
5件の回答
最も参考になった回答
check here https://www.youtube.com/watch?v=2DQpbjzK...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@kozzmic: That video only explains how to replace the full screen (LCD + glass + touch), not just the glass + touch. Seems you can buy the glass + touch digitizer without the LCD, and that makes the repair a lot cheaper, but maybe a bit more complicated: http://www.parts4repair.com/touch-screen...
Here's some insight on how to separate the glass + digitizer from the LCD. Looks like it's easy to do something wrong: https://www.youtube.com/watch?v=levTY6Ix...
さんによる 共有
コメントを追加
:) check this surprise ,
change or replace the front glass only https://youtu.be/-nFy-Ojt8oc
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i have a broken screen and wish to change it and bye a new one
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Here's the teardown in full
https://youtu.be/MdwBZ7JBxJ0
My daughter just broke mine... Not amused atm
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
HI!
It's a pain in the ass to do this and i think this dont justify to have the job done.
I used two keychain rings attached in a piece of Nichrome wire because it's very hard to broke.
I heated a little all the tablet and put everytime direct heat in the part i'm with the wire and did the job with very very carefull.
after i thought the worst part is done, i've come with the loca glue removing. I think it's harder than the first part of removing digitizer from LCD. I used Isopropyl alchool and did it finally. but some alchool go to backlight and i can do nothing. The display is now blotched with alchool in some parts.
Conclusion: With very patience you can do this but i don't think it worth the effort.
画像
画像
画像
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
blacksigma さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 38
今までの合計 8,924
