メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第2世代 Apple iPadの修理ガイド、分解、トラブルシューティング情報。Wi-Fiモデル、GSMモデル、CDMAモデルがあり、ストレージ容量は16 GB、32 GB、64 GB。2011年3月発売。モデル番号はA1395、A1396、A1397で識別可能。一部のモデルはiPad 3の発売前にリフレッシュされました。修理は難易度が高く、熱とこじ開け作業が必要です。
How to fix green/purple screen
I am in the process of a ipad 2 screen repair and I have two brand new lcds. For some reason one displays a tinted green and the other tinted purple, I have tried every method I know to resolve this problem. Now im looking for advice on what causes this issue. Would great if I can resolve this today
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
コメントを追加
5件の回答
ベストアンサー
Since no answer has been accepted yet, let me share my experience:
A/ First thing I try is disconnect then re-seat the Display Cable on both ends (using this guide): on the logic board and on the LCD. Then secure the connectors with Kapton/Polyamide tape.
B/ I test the contraption by:
1/ Gently re-seating the LCD back in place then flipping it again out of the back-case. In other words, I am causing the display cable to twist slightly and gently, and putting light stress on both connectors, to see if the change in hue occurs again. Please be gentle ;)
2/ Tapping slightly on the back of the iPad, especially around where the display connectors are located.
C/ If steps 1 AND 2 cause absolutely no change or flickering, I re-seal the iPad.
D/ If steps 1 OR 2 cause any kind of change in hue (ever so light) after or any kind of flickering, I change the display cable.
E/ I test again (repeat B)
F/ If steps 1 AND 2 cause absolutely no change or flickering, I re-seal the iPad.
G/ If steps 1 OR 2 cause any kind of change in hue (ever so light) after or any kind of flickering, I change the LCD.
From experience, 95% of cases are resolved without having to change the LCD.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Hello I good smack on the rear case will fix a wonky coloured display..
Same thing happened when I was repairing one today even after a reseed of the connector it was a green screen. So I lifted it up and hit it a smack on the back and normal screen functioned..
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
Thanks for answering, ill give it a try tomorrow
さんによる
Cheers keep us updated
さんによる
Still not working I tried your method. Its not a loose connection or a grounding issue so I'm stuck
さんによる
If a really hard good smack does not work then it needs opened up and the lcd disconnect and reconnected if still a funny display after that then the lcd has gone bad
さんによる
I tried 2 lcds. One shows purple and the other shows green. The only thing I haven't tried is to restore the firmware.
さんによる
1以上のコメントを表示
コメントを追加
I went to the Apple Store and they took out my screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The screen on my Apple IPAD2 changed from blue to pink/purple. Please help me with this problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi,
Usually that problem is due to a bad connection of your iPad's LCD, what has to be done is:
- turn off your iPad;
- open your iPad (please watch the repair guide related to it);
- carefully disconnect (on both ends) the flex cable shared by the LCD and the Logic Board;
- carefully reconnect it, make sure it is well connected;
- try turning on your iPad to check that it is working properly.
If not than you should need a new LCD.
Hope it helps :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
matthewlevy300 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 28
今までの合計 31,382
