メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
同名の社会的企業が製造したスマートフォン。より公正な携帯電話の代替品を作るための第一歩。2013年12月発売。
Touchscreen fails after reassembling
My Fairphone has been fixed before and ever since the lens of my camera was dirty. Today I cleaned it, following assembly instructions on Fixit. However, my touchscreen fails so I can't use the phone anymore. Do you know what I might have done wrong in putting everything back together?
Thanks, Annemiek
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
4件の回答
最も参考になった回答
I also had problems with the digitizer after a day in wet conditions. After some hours on a heater it worked again, but only sporadic. So I disassembled it a little bit to get to the digitizer-plug and cleaned the plug.
When water has been in an electric device, the problem is not the water, its the salt, and that remains even after drying.
And with new moisture,even if its just a little bit from the air, makes an short circuit again.
So far, after cleaning the phone workes:).
Josch
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi, I now have the same problem. Do you know ho to fix it yet?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Unfortunately I had to buy a new screen... Now it's perfect again but I hope you can solve it in a cheaper way. If you happen to live in Amsterdam, ask the Fixables in de Rijnstraat. These guys are great! Good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
allways make shure to fix the digitizer plug properly after replacing the motherboard!!!
Maybe consider Step 19 here: You have to hold the motherboard perpendicular to the dixplay unit and plug the digitizer plug.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
AnnemiekvanB さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 21
今までの合計 1,218
