メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Apple Mighty Mouseの修理情報と修理ガイド。このマウスは、レーザーセンサー、4つのボタン、トラックボールを搭載しています。
Purchase and replace ball
Something small and hard fell in the mouse track ball area and while i was pressing it (upside down) on a piece of paper to clean it, that little hard piece of dust, carved the surface of my track ball making it unable to scroll without jumping around!
So im now in the need of purchasing a new ball and replacing it! Does the ball as a part exist? Because i can't find anything on ebay! Any help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Does anyone know how to find the provider of the scroll ball Apple uses to equip the Mighty mouse?
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
Sadly, the Mighty Mouse and the Magic Mouse are deemed as not repairable by Apple. You're only hope here is to see if you can locate a dead one to steal the part to make yours whole again or look into getting a new one.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Where can i look for a dead one?
さんによる 共有
eBay is a good start, local tech flea markets
さんによる 共有
コメントを追加
genik, I am sure that you have already checked these instructions. Post an image of your trackball as well as the damage with your question and lets see if we can assist you finding what you need. If you can measure the diameter of the ball and let us know what you find. the scroll ball is nothing but a "rubber" ball with a metal core. I would suggest to measure the existing ball and get something the same (or at least very close to it) ball from places like this. Hope this helps, good luck.
update
any mechanic or machinist should be able to help you. All you need is a set of vernier calipers to measure it.
画像
Update (01/06/2016)
I thought by now you had found what you needed. Anyhow, the diameter is 7.15mm/0.2815inch
画像
画像
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
Hmm interesting, only i don't know how to measure exactly the diameter!
さんによる 共有
Is this tool offered in the Pro Tech Toolkit? Cause i see something similar... i think!
さんによる 共有
Has anyone managed to measure the diameter of the scroll ball?
さんによる 共有
genik, I sure would have thought you had it accomplished by now. I do have one left, so let me know if you want it:-)
さんによる 共有
You have what left? A scroll ball?
さんによる 共有
1以上のコメントを表示
コメントを追加
回答を追加する
genik さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 915
