メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleの2012年発売の第1世代7.9インチiPad mini。16、32、64 GBのストレージとA5プロセッサを搭載。
How to fix screen glitch?
Whenever I am using my iPad Mini it occasionally switches apps, types on its own and opening apps on its own, and also when I am watching videos it pauses and unpauses by itself. I tried everything to get rid of this please help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 122
41 件のコメント
I have this problem too I have the same thing and it types on its own and taps moves it's annoying
さんによる 共有
My iPad shuts down while your in the middle of something and it takes random screenshots and it turns its self on when I shut it down HELP‼️
さんによる 共有
my iPad doest stop glithing like crazy it closes it opens random apps it almost wanted to fro it out of the 4rt floor
さんによる 共有
When I try to turn my iPad mini on and I do my password it just keeps on glitching me out and also my screen is really cracked please help me fix it
さんによる 共有
I have the iPad air, for some undefined reason it started the glitching stuff, tried to backup and hard reset, nah!!! Doesn't mean anything, so I was thinking about buying a new screen, but I think that I fixed it by chance. How? Easy, I went to setting-general-Accessibility, then I activate the (REDUCE MOTION)=ON. Worth trying. If possible, let me know your result, then share it with everyone.
さんによる 共有
36件以上のコメントを表示
コメントを追加
6件の回答
ベストアンサー
Did this happen after a creen replacement?
If so this happens when the black tape for orignal screen isnt transferred to new screen see pic there's gold contacts need covered with the tape
画像
このアンサーは役に立ちましたか?
スコア 20
9 件のコメント:
how do u do that though, because I got my screen replaced and all of this stuff happened am I able to take it to a store and get it fixed?
さんによる 共有
Ahh when I watch on my iPad it glitch and it went to another video or app plz help me I will give you 50 dollars
さんによる 共有
My ipad mini was a giltch still
さんによる 共有
meh ipad keeps going crazy idk wats wrong with it
さんによる 共有
it just now when I play a game on it
さんによる 共有
4件以上のコメントを表示
コメントを追加
If the taping doesn't solve, then this could be a crease in the digitizer flex as next candidate. A new digitizer will solve--remember to keep the flex bent toward the LCD as in the original.
このアンサーは役に立ちましたか?
スコア 12
3 件のコメント:
Thank you very useful.
さんによる 共有
I don’t get it
さんによる 共有
Everytime I play a game on my iPad, when I loose, it glitches in middle of ads and then it automatically goes back to home screen. However, it might just be the game, paper.io, that causes the glitches, because since I downloaded that game, that was when the glitches started. But i really dont want to delete paper.io, since it's my favourite game, so is there any way to stop the glitches without me deleting the app?
さんによる 共有
コメントを追加
My iPad is constently doing the same and i couldn't get it to do anything or stop at first, but I find that getting it to shut down and reload/restart works best. Sometimes it works by just pressing and holding the lock button, then 'slide to power off' (this doesn't always work, so I also sometimes have to press the home button and the lock butten at the same time and hold them both down until it reloads/restarts
(I'm not sure if it will actually work on yours, but it's worth a try as it works on mine).
このアンサーは役に立ちましたか?
スコア 7
5 件のコメント:
i dont know if im doing this right
さんによる 共有
My off bitten doesn't work so how would I do it?
さんによる 共有
what type of ipad do you have because it could depend on the type of ipad you have
さんによる 共有
how do i stop my ipad from gilitching
さんによる 共有
is a new ipad air
さんによる 共有
コメントを追加
Shut it off turn it back on
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
It doesn't work.........
さんによる 共有
It only seemed make it worse
さんによる 共有
コメントを追加
Plug your device into your computer with a USB cable. Hold the Home and Power buttons for 10 seconds. Release the Power button but keep holding the Home button. After about 15 seconds you will be alerted by iTunes saying that it has detected a device in Recovery Mode.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
The answers about the creased digitizer flex and taping the gold contact areas are all definite fixes for this. Let me add one more that I didn't notice until I swapped a digitizer 3 times on an iPad mini. The digitizer cable end has a piece soldered on where you plug it into the motherboard. The bottom of that piece that is soldered on usually has black or clear yellow Kapton tape. Sometimes when removing the broken one, the black adhesive on the case itself comes up. If your digitizer does not have black or clear yellow Kapton tape, then the solder points on the bottom of the cable will make contact with the iPad housing and cause this issue. I was at the end of my rope with this iPad before I figured this out. If this isn't the case for you, I hope it helps someone else.
このアンサーは役に立ちましたか?
スコア 4
7 件のコメント:
How did you fix it?
さんによる 共有
"If your digitizer does not have black or clear yellow Kapton tape, then the solder points on the bottom of the cable will make contact with the iPad housing and cause this issue."
Put electrical tape or kapton tape on the back of the digitizer flex cable.
さんによる 共有
Thank you
さんによる 共有
how did you fix it
さんによる 共有
As I explained above, if the replacement digitizer doesn't have any type of tape protecting the solder points on the connector from the digitizer, it will ground out. So add tape, preferably Kapton tape.
さんによる 共有
2件以上のコメントを表示
コメントを追加
回答を追加する
Stephen さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 70
今までの合計 131,563
