メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
New battery has poor health.
I purchased the "new" stock battery for $119 and it came with 1 cycle and a supposed 5799mAh rating on the box.
After putting the battery in, the health meter told me the battery had 95% health.
Now, at 3 cycles, the battery health has dropped to 91% and 5291mAh... Is this a defect replacement???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Can you give us some background on why you replaced the battery and can you give us some more info on the replacement battery. Is it an Apple battery or 3rd party?
さんによる
コメントを追加
2件の回答
ベストアンサー
Download Coconut Battery, which may be better at diagnostics than what you are currently using. Install and run it and let us know your results: http://www.coconut-flavour.com/coconutba...
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks Mayer,
According to Coconut battery (now at 7 cycles), health is at 88.2% or 5091mAh. Sometimes it goes +/-1%, but overall it's headed downhill quite quickly.
さんによる
That drop is to fast. I'd return it for a replacement.
さんによる
コメントを追加
Same problem with MBA 2011 "new" battery purchased on ifixit europe. According to coconut battery, the battery was 300 days old when I received it. Now, after one month, it only holds 86% of the maximum theoretical charge. Furthermore, I got no answer from the support to my enquiry about this problem. Pretty disappointing...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Update : after a second trial I got an answer this time. Ifixit Europe will send me a replacement battery. I don't need to send back the defective one: that's convenient. I will make a second update to tell you if the new battery works.
さんによる
Update 2 : After 23 cycles, the replacement battery's capacity is 6200 mAh. It is a nominal value for a 258 days old battery.
さんによる
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 581
