メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AppleのMagic MouseはAppleによって製造・販売されているマルチタッチ式マウスです。2009年10月20日に初めて発表され、発売されました。
Is an inactive Magic Mouse repairable?
Yesterday my Magic Mouse stopped working. I tried several new batteries and it still won't work. Can it be repaired?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 15
5 件のコメント
When you turn it the mouse on does the green LED light up just above the on/off switch on the bottom.
さんによる
There is no green light. I've tried 10 different sets of new batteries.
さんによる
yes i even bought a new pack of nimh aa s but the pencil eraser was the solution.the contacts looked clean, but....thanks
さんによる
perfect!!! 3 times using pencil eraser
さんによる
cleaned the positive contacts as suggested - problem solved. Thank you!
さんによる
コメントを追加
4件の回答
ベストアンサー
Thats a good sign ;-}
Try using a pencil eraser to clean the corrosion and/or non conductive film that has built up on the contacts.
A cotton swab slightly moist with white vinegar can also clean up any crust from your alkaline batteries. Be sure to wipe down the area afterwards with some cotton swabs moistened with straight water (not to wet) to clean off the vinegar afterwards.
このアンサーは役に立ちましたか?
スコア 25
20 件のコメント:
Ta Da! Fixed it with the pencil eraser. Once I read the suggestion I looked, and could clearly see crud on the lower left terminal. Scrub scrub scrub - got my mouse back. Would never have thought that it could get like that, but it did. Thanks.
さんによる
Worked a treat!! Thx
さんによる
It worked (toothpick) !!
Thanks
さんによる
I had to clean the contacts several times with a cue tip and then an eraser ..three times with the eraser .. and then it finally worked. Don't give up !
さんによる
Brilliant and correct. Fixed mine with the pencil eraser. It was cruddy.
さんによる
15件以上のコメントを表示
コメントを追加
Changing from duracell batteries to energizer is the only difference in making the mouse I have work again.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I also discovered that I have some batteries with non-standard plus terminal heights. If the plus terminal heights are too short, they won’t work with the Magic Mouse.
さんによる
コメントを追加
I thought I'd post here for once, because my experience was different... I tried all the cleaning tricks after all the other battery troubleshooting, and still no green light. At all. Just quit, went dormant or something. I decided to delete the mouse from my Windows o/s, and just put the mouse aside; kind of clicked it and checked the light several times a day, nothing. Then, three DAYS later, I checked again and the green light came on, once. Baffled, I decided to re-pair to my o/s, clicked and clicked, and voila! It started working again. Perfectly. Perhaps it just needed a vacation! It's a very heavily used mouse, first generation Magic Mouse. Baffling.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you use a nail file gently it should work. Make sure the contact point is smooth and cleaned off. I used the cotton swab at first with alcohol and it didn’t work.
このアンサーは役に立ちましたか?
スコア -1
3 件のコメント:
I used 600 grit sandpaper and took my time. I had previously tried a pencil eraser (which is a known fix for cleaning the contacts of electronics) but it did t work this time.
さんによる
Best not to use either as both can be a bit aggressive and can leave metal filings which could make things worse.
さんによる
@danj Heh I'd try it if all else failed. Nothing to lose at that point.
さんによる
コメントを追加
回答を追加する
Mark Stone さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 21
過去 30 日: 70
今までの合計 22,951
