メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
締切られた回答
How long for "preparing to remove partition"
Trying to repair and upgrade my daughter's macbook. Installed 500 GB hybrid drive and two 4MB memory cards.
When I first fired up her macbook I got the flashing question mark folder. Plugged in a 1TB LaCie time machine backup from my wife's macbook. I was able to boot and run Disk Utility to partition the new drive. But somewhere along the line the new partition got named the same as the LaCie partition - namely "LaCie". I tried a bunch of thing and I'd get messages like, can't unmount, ... Now I'm trying to remove the "LaCie" partition and get a name I want. The Disk Utility gives me the message "preparing to remove partition" along with the horizontal progress bar. It's been running forever. What can I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
Can you give us the last four digits of your serial number so we can correctly identify which model you have.
さんによる
066E
I don't really have the problem I described earlier. I figured that one out I was trying to reparation the "LaCie" drive I "booted" from. Once booted from the LaCie I was able to partition the new 500GB Hybrid drive. I think somehow I've got to get the OS X Maverick on the new drive, but the LaCie is "Lion". I may have to give up on this and see if I can get a refund on the iFixit order. I've upgraded drives and memory before on a couple of MacBooks, but this looks like it'll take more understanding than I have. Thanks, sorry for any trouble.
さんによる
MacBook Pro "Core 2 Duo" 2.53 13" (SD/FW)
さんによる
Can you give us the make and model of this HD you are working with.
さんによる
Products ordered:
500 GB SSD Hybrid 2.5" Hard Drive / Drive Only
Quantity: 1
Price: $99.95
This is the drive I purchased from ifixit and installed. I formatted one partition something Mac Jornaling - the default selection.
さんによる
1以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Thanks everybody, she up and running. My problem seems to have been trying to boot from Lion. Once I booted from a Lacie back up of my Maverick all worked. Now I have to machines that are identical to each other; i.e., two "my machines", now I'll just have to restore my daughter's MacBook Pro so it becomes hers again.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Happy it all worked out!
さんによる
コメントを追加
最も参考になった回答
Re-partitioning drives can be confusing. The trick here is one needs to be booting up off of a different drive than the one they are altering. Make sure your connection is good and the unit has enough power. If you can use an external power adapter as some systems can't supply enough power and will cause hangs like this. If you got a dual plugin USB cable with the drive make sure you use it and plug in Both plugs!
As to different OS-X versions. If you are altering an external drive (one that is not bootable) the OS-X version on the most part is not an issue (Lion or newer) all of these OS's use the same low level formatting. What can happen is the external disk might have a Windows based format (FAT) that has limits even though your Mac can work with it the alteration of the partition maybe beyond what the FAT format can support.
Here's some Apple TN's on OS-X formats and limits:
And lastly, here a good breakdown on the different Windows format types: NTFS vs FAT vs exFAT.
If you are planning on making it a bootable drive (swapping it out for the older internal drive) make sure you have the version of OS-X you want to install on your system. You really can't install a different version of OS than what you have booted up with. And you can encounter problems with a drive that is setup with too high a level of OS than what the system can support.
You make comment of a MacBook and a MacBook Pro do you have both here? If you do then you could be creating a problem if you are setting the drive up under your MacBook Pro to then install in your MacBook (OS wise).
You can also have an issue with the systems SATA I/O speed. Many of the MacBooks systems can only support SATA I (1.5 Gb/s) HD's is the drive you are trying to install a SATA II (3.0 Gb/s) or SATA III (6.0 Gb/s) drive that can't have it's I/O speed lowered to SATA I (1.5 Gb/s)? You may need to get a different drive.
I do recommend checking and updating if needed the systems firmware as Apple has addressed some HD issues in the firmware. Follow this Apple TN:EFI and SMC firmware updates for Intel-based Macs
Lastly, be careful on how your drive is partitioned many have a small boot partition to hold diagnostic utilities as well as OS installers (newer Mac internal drives).
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
if its been long enough for you to ask its been too long and is likely just frozen, i would try to boot into recovery with the time machine backup drive unplugged and try to format it that way
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 10,245
