メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox Originalは、Microsoft初の広く普及したビデオゲームシステムです。上部と前面に「XBOX」のロゴが入った、識別しやすい黒いケースが特徴です。一般的な工具で簡単に修理できます。
Xbox wont turn on?
My original Xbox has been sitting in a cabinet and is in like-new condition. It worked perfectly until one day when it wouldn't turn on. I thought it might be the power cable because I've read that the original cables can be faulty/were recalled. So I bought the new power cable but this still didn't work. The console doesn't make any noise or anything when I press the power button. It acts as if it is getting no power. Anyone know what's wrong?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 15
15 件のコメント
Hello, Im new to this forum but was brought in by a search because I too have the same problem, my X-Box was working when I believe due to a power out it no longer turned on, this was within days of each other, I read that it most likely be the power supply, I have ordered an original V.6 replaced it and still doest turn on, Now I read that it could be the Mother board, Is this possible and if so, I know that if I need to order one it would come with a new or other HD because the current one will not work with the new motherboard, my question with this is, once the new MB & HD are installed, It would be as if a never used X-Box, oviously no stored memory.. Would this be my best bet to get it going or are there some things i can look for on the current MB that i may be able to fix?
Thanks
さんによる
I have this current issue. This week, after 15 ½ years, my Xbox won't power on anymore. It stopped working today. Prior to today, for weeks, I have to hold on the power button for a few minutes to boost up the system. It used to be in perfect shape from December 25th, 2004-May 26th, 2016, until I bump to this issue. I have to hold the button to power on the system and it works. On June 28th, 2016, it won't power on (I hold the power button for 15 minutes and it still won't power on) and today, July 2nd, it stopped working. My dad said the power button got bad (a YouTuber claims the wires got loose). Is there a way to fix this problem? I can turn it in to a repair shop that repairs video game consoles or buy a new one so I can switch the hard drives (I do not want to start my games I still own from 2004-present all over again on a different hard drive). I need to know the problem why it won't work.
さんによる
My Xbox has a mind of its own.it keeps cutting out after I plug it in and I do this a few times.sometimes it comes on after a few trys but it's getting very frustrating for it not to turn on straight away can someone please help I'm going insane
さんによる
My Xbox want turn on and it’s plugged in. I tried everything but it dose nothing.
さんによる
My xbox original not torn on please help and alladin xt plus 2 blue lighte on
さんによる
10件以上のコメントを表示
コメントを追加
8件の回答
ベストアンサー
You need to open the system, check if the power supply is a foxlink. Foxlink power supplies have a bad solder job and you need to resolder the power plug so it will work again. (Reason being is because you have stated that the cord has been replaced, so therefore internal issue)
To Open the Xbox console, you will need a couple of special tools. You will need a TORX T-10 screwdriver and a Torx T-20 screwdriver. The XBOX case has 6 T-20 screws and to remove the hard drive and DVD drive, you will need to remove 3 torx T-10 screws. The power supply is held down by 2 torx T-10 screws.
http://www.llamma.com/xbox/Repairs/power...
The link above explains how to fix the issue.
If this has helped please vote the answer and accept it. Many thanks and all the best
このアンサーは役に立ちましたか?
スコア 9
5 件のコメント:
I have my xbox gutted and the power supply removed. All the soldering contacts look fine. Any other ideas on what might be wrong?
さんによる
All of the capacitors look fine too.
さんによる
I got my Xbox to turn on by using a paperclip to bridge the gap between the white and brown pins on the power supply connector as seen here: http://diy.sickmods.net/Tutorials/Xbox1/... The problem now is that it turns on but will not boot because the ring turns solid orange and the system doesn't boot or output video or sound.
さんによる
I am having the same issue.. What are some places that I can ship my XBOX to for them to repair the system.. Does anyone know if you give me some places I will search for them online and call them..
さんによる
I only 10 I DO NOT KNOW how to fix my xbox,I plugged all the cords in and it didn't turn on.Then I realized "Oh Great, The Powerbox Light Was RED!" I tried to try my other Powerbox and as soon as I plugged it in the powerboxes light was FLASHING ORANGE!"I don't think that's normal" . Sooooooo! I took every cord out and put them back in to realize"yep that did not work my xbox would not turn on at all"
Well it's 11 years old older then me ! R.I.P Moonas Xbox360 u will be missed have fun in Xbox heven! Pls help meh this issue will be killed at my xboxes freanel.r.i.p my xboxbox
さんによる
コメントを追加
My xbox original only boots when the AV cable is out….when i put the AV cable in the xbox, it turns off. somebody knows how to fix this? I already changed all of the 3300 uf 6.3v thingys.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Try a different AV cable. The one you have must have a short in it that causes the power supply to shut off/not turn on (over current protection).
さんによる
コメントを追加
I have the same problem, the symptoms your Xbox is having sounds like a burnt fuse. If that is the case,fuses are usually about .10$.(extremely cheap) I don't know how to gain access to the fuse though...It's probably on the power supply board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Most likely all, but the 1.6 version, Xbox's clock capacitor has leaked electrolyte onto the motherboard and done damage to the motherboard. The electrolyte needs to be cleaned with isopropyl alcohol and cotton swabs or a soft toothbrush. Most likely on the bottom side of the motherboard some of the traces along the edge that carry the power and eject control signals have been corroded and need to be repaired. Trace repair tutorial for v1.0-v1.5 systems - http://theisozone.com/tutorials/xbox/har...
Update (04/24/2021)
Sounds like the clock cap has leaked electrolyte and corroded the trace that carries the power button signal trace on the bottom side of the motherboard. Breaking continuity from the front panel switch to the System Management Controller on the motherboard that tells the power supply to turn on. You'll need to open the case and clean the leaked electrolyte and repair or jump over the broken trace.
See: http://web.archive.org/web/2015022717064... for more information.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey, so my Xbox wasn’t turning on too but I went to the wall outlet where my Xbox is plugged in and if you have a lot of wires at the back of your tv, the plug eventually falls out so check if it’s plugged in and see if there is a white and orange light on your system (not your Xbox system). Hope this helped! Xoxo
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well personally my XBOX had a similar problem, but instead of it not turning on it would never turn off. I was able to fix this problem by kicking it really hard a couple of times and that seemed to do the trick. Now it’s not turning on which is extremely frustrating but I’m working to figure out why it wont turn on.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
さんによる
U shouldn't have &&^&^$^ kicked it
さんによる
コメントを追加
So I figured out if your original Xbox won’t start up when pressing the the power button on the console, try plugging a controller that is synced to the Xbox into the wall, press the middle button on the controller to turn on the Xbox and it should work. Only when plugged into the outlet on a wall
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
i have the same problem too
さんによる
Original xbox? They got wired controllers bro
さんによる
さんによる
コメントを追加
I had that problem too well yes im bot even 13 but i think i found a souliution u should span the power on button a lot until it will start power up (tough it only a half-soliution i spend around 15-30 minutes everyday till it turns on)
このアンサーは役に立ちましたか?
スコア -1
2 件のコメント:
Not even 13*
さんによる
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 57
過去 30 日: 287
今までの合計 91,449
