The touch screen is unresponsive
I keep pushing on the touch screen but nothing moves? What should I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The most likely problem is a loose connection on the inside.
Check the connections of the ribbons on the inside of the device. Follow the motherboard removal guide to get to the ribbons.
If this doesn't work, the digitizer may need to be replaced. However, a guide is currently not available for that. To replace the digitizer, one would follow steps similar to the screen replacement guide, but put the components in a new digitizer.
ガイド
難易度:
難しい
15 - 25 minutes
ガイド
難易度:
中レベル
30 - 45 minutes
このアンサーは役に立ちましたか?
my tablet is in a sleep mode and will not wake no matter what I do.
Tried on and off, reset button and power and up volume button at the same time and nothing changes
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 9,690
4 件のコメント
It will work with A mouse
hmrogers01 さんによる
the glass is cracked will this keep it from working
hmrogers01 さんによる
It isnt working not alittle.
Richard James さんによる
my screen is cracked and the same thing happening how do I fix this
Fantasy Anime Lover さんによる
