メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duoプロセッサ
LCD Backlight not working = solved
Hi,
I have an iMac 2009, 21,5" which has been working well until last week. First there was some flickering and sometimes a black display. Since yesterday the display seems not to work anymore.
I have found the apple technicians guide for this iMac online and tried some of the solutions described there. I did a SMC/PVRAM Reset, but this did not solve the problem.
To determine if it's the gpu I connected an external monitor -> everyhing working fine on the external monitor.
It seems that the LED backlight isn't working anymore, because if you use a flashlight you can see everything on the internal screen.
I asked at a local repair store but they told me (without looking at the device...) that it was either the LCD panel, which would cost almost 500€/650$ to replace or the SATA/Board (Logic board?) which would even be more expensive.
My question is whether it's possible to determine if it is the logic board, ta cable connection, the Backlight controller or the LCD-Panel.
Thanks fpr your answers,
Max
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
8 件のコメント
Thanks for all your comments! Can anyone explain how to check the Pin voltages on the board? I have a Multimeter and I would just check them. If there is some low voltage would that mean that my power suppy is not producing enough power anymore or what would be the implication?
I just don't want to spend a large amount on something (LCD-Panel, power supply or inverter board without beeing sure if it really is this part...
Thanks,
Max
さんによる
Hi Max, sorry this is 3 years late, but you should get an a/c voltage at the pins, 0.012 volts.
さんによる
Jack, it may be three years late for Max, but right on time for me. Thanks.
さんによる
and again now for me two more years on
さんによる
and me.. but partially the lower right part backlight is not.working, what can i do?
さんによる
3件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
Max Beck, here is what Apple suggest in how to test the components:
Quick Check
Symptoms
Backlight Issue/No Backlight
• No image
• Partial backlight failure
• Backlight flickers
• Display dim
Quick Check
1. Check for Software Update.
2. Verify that System Preferences > Displays >Brightness control setting is above minimum.
3. If no image on built-in display, connect external display to verify if iMac video circuitry is functioning. If no image visible on external display, go to No Video symptom flow.
Deep Dive
Check Result Action Code
1. Verify boot chime present and fans running when computer powered ON. (Reset SMC and clear PRAM if necessary for proper boot up.)
Yes Power on self test OK.
Go to step 2.
No Go to Won’t Start Up
symptom flow.
2. Verify if image is visible on built-in LCD panel, with adjustable backlight level.
Yes Video present. Verify system functionality and return to user or go to appropriate
troubleshooting flow.
No Go to step 3.
3. Connect supported external display. Verify if image appears on external display when system is booted.
Yes External display detected by system. Video circuitry on logic board functional.
Go to step 4.
No Go to No Video symptom flow.
4. Verify if LCD backlight is ON by looking for faint glow from display when viewed in darkened room with brightness set at maximum.
Yes LED backlight is functioning.
Go to step 7.
No
Go to step 5.
5. Shine bright (low heat)flashlight onto front of LCD. With computer powered ON verify if a faint image is visible.
Yes LCD panel functional but backlight is missing or dim. Remove LCD panel and inspect and reseat the following cable connections:
-Output cable between lower end of LED backlight board and lower end of LCD panel.
-Vertical sync cable between upper end of LED backlight board and LCD panel.
-DC power cable between upper right of LED backlight board and power supply.
Replace any damaged cable.
Reinstall LCD panel and go to step 6.
No
No image or backlight.
Go to step 7.
6. Power ON system. Verify if image is now visible on LCD panel with correct backlight level.
Yes Issue resolved.
No Replace LED backlight board.
Retest. If issue persists, go to step 7.
7. Inspect and reseat LVDS cable between LCD panel and logic board. Power ON system. Verify if image is visible on built-in LCD display.
Yes Issue resolved.
No Replace LVDS cable.
If issue persists, replace LCD
panel. Retest.
You can also check on Logic Board Test Point pin 6 to see what voltages you get there. Pin 6 tests Backlight Control pulse width modulated signal (from logic board to LED backlight board, to adjust the backlight level setting according to user setup). Use a multimeter on the DC scale for that. To find the proper backlight board, it would help to get the last three digits of your computers serial number. Here is the guide showing you how to replace the backlight board. Hope this helps, good luck
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
OT - is my research on this one faulty? http://www.ebay.com/itm/Apple-iMac-A1311...
さんによる
@mayer, no Sir. Just trying to answer this part "is it possible to determine the reason?" of the question :-)
さんによる
コメントを追加
最も参考になった回答
I would suggest never going back to the repair shop that did not even open the iMac and told you it was the LCD or the MLB. I am an Apple Consultant and also repair only Apple computers, so I have been in quite a few iMacs. Usually ends up being the backlight board but always check the cables because I have had 2 that I can remember where another repair shop and even the Apple Store had done a repair not related to video issues but messed up the v-sync cable. The v-sync cable is very delicate and you can easily mess the pins up or crimp the cable causing intermittent or total loss of backlight. I know you have solved your issues but thought I would add this for anyone else searching on how to fix this problem.
このアンサーは役に立ちましたか?
スコア 9
2 件のコメント:
Hello, I've got this problem : my iMac 27" mid 2011 sometimes gives me a dark alone in the lower left corner of the screen. Then it fix by himself and then gets dark again. Apple Repair shop told me to change all the display panel. What should I do? Can you please me give me a help ? Thank You
さんによる
Never buy mac,enjoy windows,eat mc bacon
さんによる
コメントを追加
Replace the inverter. The working external monitor clears both the logic board and the GPU. Look on the board for Apple part # 612-0073, possibly 661-5537.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Thanks, but couldn't it also be a unsufficient power supply or damaged cable connection then?
さんによる
@Max Beck, no. Not the power supply, a damaged cable possibly, but unlikely.
さんによる
@mayer
I have this exact problem. REPLACED the inveter with a new one and nothing worked.
Do you think could it be the cables that connects the INVERTER to the power supply?
さんによる
What year? Mine was the ccfl tubes blown, got replacement tubes from a supplier in Poland, simple swap out, no soldering.
さんによる
CCFL tubes. Never heard of that. Where is it located? How did you find it was the problem?
さんによる
1以上のコメントを表示
コメントを追加
Problem solved: Bought used LED Board and replaced the old one following the online guide. Seems that this was the reason for the black display ;)
Thanks to all the helpful members who helped me a lot with finding out which part was broken!
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Have the same problem here with a mid 2010 imac EMC 2389 - A1311z I bought a new led panel with new inverter board.. but still got black screen. Important: diagnostics led 1,2,3 are ON and Led 4 OFF and don't blink on startup.
Please help me guys!!!
さんによる
Does it have ccfl backlights or led? My 2009 has ccfl that are gone in the screen. Can you still see the images on the screen when it's on if you shine a torch on the screen? If you have replaced the screen and inverter and you can't see anything, try the vsync cable
さんによる
Cristiano an solve your problem?
さんによる
@volatileloser34
It doesnt make any sense!
@Danual ????
さんによる
Sorry, just realised it's LED backlights not CCFl tubes, mine was early 2009 and an easy fix as the tubes were blown. If you've change the inverter for new and still no working, check the supply power if you can.
Mine was12v
Gnd-ground
En-3.3
Dim-0-3.3v (dependant on brightness setting)
Gnd- ground
さんによる
1以上のコメントを表示
コメントを追加
I’ve had the same problem on a 2009 27” Quad Core i7 iMac.
  1. The display comes on but the backlight will not stay illuminated unless set to a lower setting (+3 on the scale).
  2. I have found that when the light nears going off, the 3.3 volts coming from the Logic Board to the backlight inverter board has sagged to 2.9 volts and suddenly drops to 2.7 volts when the backlight goes off.
  3. When the backlight has failed, I can use keyboard commands to make it sleep and then reawaken, but the backlight will not stay illuminated unless set to the lower illumination setting of +3 or less.
  4. I have found that if the computer is unplugged overnight, the display will run at full illumination for about four hours before the faulty behavior begins to occur again.
  5. I have read elsewhere that the 3.3 volt signal to the backlight board is what commands power to the backlight or turns it off. This voltage is supposedly generated by the Video Card.
  6. Others have claimed they have severed this connections and provided an alternate 3.3 volt signal to the inverter board so it always stays on. This will be my next step to see if the problem can be remedied.
Has anyone had any experience with regard to the 3.3 volts going to the inverter board?
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Wow. This give me a way forward!
I was going to replace the display power supply inverter, but held off on that. I suspected a faulty LCD temperature sensor, which is trivial to replace. Nope. My next step was to swap out the GPU.
FWIW the iMac I'm working on was a Core 2 Duo model. I swapped out the motherboard for a Core i7 860 (Nehalem, Core i first generation). The display still drops the backlight at unexpected times.
さんによる
@watersb I replaced the LCD Temp sensor on mine but this did not seem to help. I assume the sensor was good (it was an eBay Purchase). I have wondered if a temp sensor (one of many) is slowly dropping the 3.3 volts signal coming to the Backlight Inverter Board.
さんによる
コメントを追加
I have this issue in my mid 2010 2.93ghz i7 iMac. I just replaced the backlight board this morning and its still exactly the same. The LCD is displaying an image, but the backlight wont stay on.
Any ideas? Do i need to replace the LDVS cable now?
Update (03/11/2019)
PS. I can get the backlight to come on briefly with the shift-ctrl-eject keystroke. But it doesnt stay on for more than a couple of seconds. This is with the old backlight board and the new one. Surely the LDVS cable wouldn’t react to a keystroke like this? What else could it be?
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Try turning the backlight setting all the way down and then start turning it back up and see if the backlight comes on for a second before shutting off. If it does turn on briefly when doing that, it is definitely the LCD. It is most likely the LCD anyways if the backlight board did not fix the issue. I'm sure you have probably already tried this but reset PRAM and SMC. You can try and replace the LVDS cable but most likely that will be fine, I have fixed probably 500-700 iMacs and I can not remember ever having the LVDS cable be a problem with a backlight issue.
さんによる
Thanks for your reply. Yes, the screen does as you described when I turned it down/up. I contacted a local mac repair centre who said based on what I've described, with the backlight board already replaced, the issue is the backlight itself. They're going to replace the backlight in the LCD (for 170 euro), which they said was a common failure. Good news is I can get a full refund on the Backlight Board. Not too bad I suppose. I've had it 9 years, and its still brilliant. So a 170 repair bill for 9 years of terrific usage isn't bad!
さんによる
The other thing it does is, if I use the ctrl-shift-eject keystroke but keep my fingers on the ctrl-shift buttons, it stays on. For a while anyway...
さんによる
Hi Brian!! I had just finished putting a mid 2010 i3 3.2 board and I get 123 leds to light on but not the no. 4. My V-Sync ribbon looks a bit mangled but I managed to repair (so I think) but still black screen I do get and image using an external display. T_Shoot talks about fiddling with brightness but using external monito I don't see this on my mac system settings. Im replacing a bad 2009 board with the mid 2010. My screen was working before so it should work with the 2010 board. I got the proper cable/connectors/sensors that were different from 2009 board. Where should I test pins to rule out board or what else? Thx!!!
さんによる
I'm the tech at a school which has about 150 of these iMacs. Of the 150, approximately 1/3 of these have the exact same backlight issue. They were purchased in 2009 and began going out around 2017. They began to drop like flies in 2018. It's only a matter of time before the remaining iMacs join those in the tech salvage graveyard. This proves that Apple pretty much uses components meant to stop working after a specified period (likely to get you to buy another iMac). It's crazy that so many of our iMacs exhibit the exact same problem. This is why I've sworn off Apple products; they use inferior hardware and are basically set to self-destruct and then make it very difficult to self-repair, forcing you to purchase another of their inferior products. I'm not going to spend nearly $2,000 on a machine that's pretty on the outside but has cheap hardware on the inside designed to prevent me from repairing it myself and set to self-destruct after 7-10 years. No, thank you.
さんによる
コメントを追加
Solved!
After almost 3 years, due to the fact I was unable to stop and take my Imac for Repair since I work with it to make my incomes.
Basically the issue happens because the L9000 Circuit burns if you misconnect the LCD Display cable. I followed all the hints to check the LED Start sequence as you can see on this LCD Backlight not working = solved to this problem. I noticed that LED4 was not blinking on the startup sequence.
I connected an external display using Displayport and the Mac was running fine on it.
The next step was to buy the circuit from Digi-key, as mentioned by Yako on this Damaged display power header whilst replacing hard disk drive. You can buy the 220 OHM Ferrite Circuit here.
Next, I took my iMac to an electronics specialist who confirmed that the Circuit was burned. He welded it again and TADA, LCD working again!
SOME TIPS:
a) The L9000 Circuit is below the GPU. So you will need to remove the logic board and the GPU (the whole thing with the cooler, etc.) Check the picture below to see where the Circuit is located
画像
b) I Paid something like $10 for 5 220 OMH Ferrite Circuit on Digi-key. Link above.
Here are some pictures after the burned Circuit was removed and the new circuit Welded.
画像
画像
画像
画像
画像
c) I paid $200 for the welding service and repair.
If you’re facing the same issue and you’re in Brazil, contact RG Telecom.
Thanks, everyone for the tips. Thanks a lot, everyone here for the tips and help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Max Beck さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 76
今までの合計 71,213
