メインコンテンツにスキップ
AppleのMacデスクトップもしくはラップトップコンピューター用のオペレーションシステムです。
71回答 すべてを表示
締切られた回答
Why is my computer geting slow
everytime i use my computer, its starts fine and after an hour everything starts to get slow. on firefox but also on itunes and iphoto. the same happen with my old computer after a few years.
is it because i have a lot of music and pictures?
i always do my updates as well.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
It sounds like you need to do some house cleaning
Over time log files and other temp files build up every time you run an app or just boot the system. There are a few cleaners out there that can help you here. While you are at it delete anything that is just taking space needlessly.
This one is a little bit hard as you need to boot up under a different drive. This can be a USB thumb drive a USB or FireWire connected Hard Drive (some models won't boot under USB) or a CD/DVD that you have: Grey recovery disk or retail version of OS-X or one you have created. Once you have booted under the other drive you can then run Disk Utility from it to repair your internal drive. I do recommend making a backup copy of your files onto an external drive first just in case the drive fails.
The next issue is disk fragmentation. While people swear modern OS don't fragment this is a half truth. The issue is not the OS but filed you add and modify often frag. To resolve this you need a de-fragmentation tool. I personally like Drive Genius. there are others out there that will also work. I like zip in my system so I tend to run it twice a year (I work with quite a few files). Some people only need to do it once a year.
While you're at it you might want to think about cleaning out the dust build up internally. This will require opening your system as you didn't give details on it you'll need to post a new Question for us to cover that.
Basically, its just like owning a car, you do need to tend its maintenance needs so it runs smoothly and can give you a long life.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Another issue is RAM fragmentation. Web browsers are notorious for sucking up more and more of your RAM the longer they're running; older browsers (and older operating systems) are worse about this. Many of these browsers don't completely release the RAM when you quit the program; the RAM that the browser was using remains in a chunk separated from the rest.
Unfortunately, there's usually not much you can do with this except restart the computer. You can purge the unused RAM using the 'purge' command in Terminal, which will often relieve the problem. I perform the purge operation often enough in Snow Leopard/10.6.8 that I wrote the Purge command up as an Applescript application. You can download it here; it may not work on operating systems later than 10.6, and I'm guessing it won't work if Terminal isn't in the Utilities folder. The first link also leads to instructions for running the Purge command under Mavericks, which may also apply under Yosemite.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Simply reset your browser and it will start working fine.
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 5
今までの合計 362
