メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1990年から1993年モデルの第4世代 Honda Accord。クーペ、セダン、ステーションワゴンの各シャシーで展開。
loss of power please help
Im loseing power right after startup, even if its warm up alread... turn in car as soon as I start giving it gas it boggs out I let off gas and give it gas uts fine problem goes away but seems to start getting worse????
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
What engine size is it and what have you tried to fix it so far.
さんによる
2.2 liter. I changed oil and filter,spark plugs CV joint. Gas treatment n tank,and air filter
さんによる
Sounds like the catalytic converter unbolt it or cut it off and see if it fixes it mine was just replaced for $160 at a muffler shop and it runs like new again!
さんによる
コメントを追加
2件の回答
ベストアンサー
Mike, if memory serves me correctly, that Honda has fuel injection. That being the case, it sounds like your fuel pressure regulator isn't functioning properly. An electronic fuel pump is located in the gas tank. That pump gives off a constant pressure and that pressure is then regulated to the fuel delivery rail by allowing some of the pressure to bleed off back to the gas tank on a return line via the fuel pressure regulator. The fuel pressure regulator is vacuum operated, so take a look along the fuel delivery rail for a sort of cylindrical apparatus with a vacuum line attached to it. Insure that the vacuum line is not cracked and leaking. Repair or replace that first if it's bad. You can check vacuum leaks with a hand vacuum pump available at most auto parts stores. Just make sure that line isn't leaking. Vacuum leaks can also present themselves as rough running (not smooth idles). The fuel pressure regulator is an easy replacement if it's bad. The fuel rail on your car is a shiny aluminum stick that runs along the back side of the engine between the engine and firewall. The fuel pressure regulator is located on the drivers side of that rail. You also may want to have a dealer run fault codes on the car. That car is equipped with an OBD interface under the steering column. It looks like a old style computer cable terminal connector. Sometimes the fuel pump is faulty, but in order of least expensive repair, the vacuum line to the fuel pressure regulator is only a few dollar. The fuel pressure regulator is maybe $60, but the fuel pump is about $500 for someone to replace it. I am enclosing a vacuum line map that will show the fuel pressure regulator.
Let me know how it works out.
画像
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thank you I will check it,or best too go head and replace it.
さんによる
Great description of what to look for. Trying this fix on a 93 Honda Accord anniversary edition that bogs under a load.
さんによる
Mine does all of that getting worse n I smell gas. I’m my shoes, could be x boyfriend? Won’t stop games! Any ideas
さんによる
コメントを追加
In a lot of these cases on 4th Generation Honda Accords, the loss of power and bogging is because of a bad O2 Sensor. There may, or may not, be a Check Engine light. They oxygen sensor can become erratic without throwing a code.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I also had similar issues with a 2000 accord when the catalytic convert became clogged.
さんによる
コメントを追加
回答を追加する
mike さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 23
今までの合計 34,515
