メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年にMicromax Mobileから発売された、スタイラスペン付きのファブレット型スマートフォン。
Micromax Doodle 2 Running Problem?
OMG i was try to change font style after changed it it appeared reboot. i was press ok then mobile was rebooted. after reboot Writen theme only CANVAS DOODLE 2 screen will appear after that nothing to goto desktop screen. i am Stress now please anybody can give solution on my micromax doodle 2. i was try to format the device and wipe data factory also i was reset. please anybody give solution on this problem.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
8件の回答
OK Try this.
Download the Android Stock rom of your micromax device model to your pc from this site:http://mxrootrom.blogspot.in/2013/12/sto...
Then insert your sd card in a card reader and connect it to pc (Don't use device to read sd card,it may not work).Then create a folder named 'root' and move the stock rom(ZIP File) to the root folder in the sd card.Now insert the sd card into your device.
Get into recovery mode and wipe your device and also remember you must wipe out the'dalvik cache' also.
In the recovery mode,select 'apply update from sd card' and browse for the zip file in the root folder of your sd card and select the stock rom file.
Now it will take time to install the stock rom on your device.
Now all things are set right.
Then reboot your device.Your device will function properly.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Without sd card slot how you will install the stock
さんによる
コメントを追加
Same problem.. and denesh there is no external memory card slot in DOODLE 2, it has a bilt in 16 GB memory.. so we can't use card reader to read our Sd card. :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Download odin v3.0 then click on pda and then select that file (u must extract the zip) then click on start
...u need to connect ur phone to pc .. ur phone must be in download mode .. it will do everything on its own.. enjoy
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How you will put download mode if you cant see any thing except canvas doodle 2 boot screen.
さんによる
コメントを追加
Download odin and that file on ur pc
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Run odin and then connect ur phone to pc
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i solved the issue, on the canvas doodle 2 screen,
1. if your phone is screen lock just swife, swife , swife, swife on canvas doodle 2 screen, where it got strucked.
2.hold power botton and just tap tap tap tap at the screen area where we can see power off screen at the time of power off.
After doing the same process several times ,your phone will be switch off. This we are doing without seeing the option like blind person.
After switch off your phone hold the power and volume of volume down button to reset in factory mode.
This process i have done yesterday now my phone is working fine.
Try this and good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have installed cyanogenmod but then i started having problem so i rebooted then wipe cleaned files and formatted sd-card after that i cannot mount my sd-card plz help
it is showing- E:Unable to write ums lunfile (No such file or directory)
my phone is micromax doodle 2 A240
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi i am nitin, in my micromax doodle2 my wi fi is not turning on and also my bluetooth is not turning on..althought i have reset my phone aswell..but then also its not working.please help.
thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Giriraj Kulanthaivel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 3,232
