How to change the aluminum socket
How can I take the aluminum socket of an iMac apart?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
do you mean the stand ?
i don't have the manual for the 21.5" model - bt i think it's pretty much the same as on the other models
first you have to diassemble almost everything from the iMac
i think the logic board guide fit's best for that.
than you have to remove 7 t10 screws from the stand and than you can separate the stand from the clutch mechanism and rear housing. reassembling is the same thing - only reversed ;-)
このアンサーは役に立ちましたか?
danke!
bitte ;-)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,629
