メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
muffled speakers because I dropped it in ice cream
I first attempted to clean the small holes with a napkin that did not work so I looked it up to find a suggestion to use an electric tooth brush it changed it slightly but not very much at all. should I try to leave it in rice over night? please answer as quickly as possible I'm terribly sorry I'm just freaking out a bit. thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント
i did the same thing and im trying do use the rice method
さんによる
Rice method won't solve the problem. You will actually have to clean the phone and clean it of liquid damage to avoid more problems in the future. It is advised to use 99% isopropyl alcohol and clean all the contact points for ribbon connectors such as front display ribbon plugs, logic board plugs and even on board components as you don't want them to burn out.
This is an off topic question to others:
- I recall seeing a thread about an iPad 2 digitizer repair a few days ago saying that they can wake up the iPad with the home button but the power button actually works when you hold it to turn it off but the power button would not wake up the iPad.
Did anyone else see this post somewhere recently? Because I was going to post a solution to it which would be the power & volume flex cable not seated properly or damaged.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Just put kettle on and wait till its starts steaming leave for 5sec and suck the speaker keep doing it for a few mins and boom it worked for min and mine was mint icecream
このアンサーは役に立ちましたか?
スコア 4
5 件のコメント:
what if there is a white spot
さんによる
Can you be more specific, what do you mean by putting it on a kettle???
さんによる
Something similar happened with my iPhone 8...the day I got it I dropped it on a muffin and now the left bottom speaker sounds horrible.... I would love to try out your meathod, im just not sure what you mean. pleas contact me asap, :) im really worried
さんによる
He means put your phone over the steam for 5 seconds then suck out whatever is in it
さんによる
I really hope this steam way works cause I sorta dropped mine in banana pudding
さんによる
コメントを追加
I had a similar situation to this, My new 6th gen ipod touch fell in yogurt and the speakers arr clogged but i poked the speakers eith a needle and ut worked
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
The device needs to be properly treated for liquid damage. I strongly recommend powering it down and leaving it off until you address this condition. Do not rely on rice to take care of this! You can find a technique guide here. Go to the iPhone 5s device page also and review the teardown before you attempt to do anything so that you can be better informed as to whether or not this is something you are comfortable tackling. A word of advice: if you do choose to disassemble your device, be very careful of the ribbon cable for the Touch ID sensor.
Good luck to you!
If you found this helpful, please up-vote or Accept Answer.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
thank you very much! I don't think I'm confident to do it myself but thanks for telling me what's going on!!
さんによる
コメントを追加
if you drop it in ice cream/pudding/chocolate ect i recommend scooping the chocolate out with a needle and then using a dry electric toothbrush and rubbing it on the speakers. it worked for me!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
abbie さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 53
過去 30 日: 234
今までの合計 64,928
