muffled speakers because I dropped it in ice cream
I first attempted to clean the small holes with a napkin that did not work so I looked it up to find a suggestion to use an electric tooth brush it changed it slightly but not very much at all. should I try to leave it in rice over night? please answer as quickly as possible I'm terribly sorry I'm just freaking out a bit. thank you!
2 件のコメント
i did the same thing and im trying do use the rice method
Michele Spafford さんによる
Rice method won't solve the problem. You will actually have to clean the phone and clean it of liquid damage to avoid more problems in the future. It is advised to use 99% isopropyl alcohol and clean all the contact points for ribbon connectors such as front display ribbon plugs, logic board plugs and even on board components as you don't want them to burn out.
This is an off topic question to others:
- I recall seeing a thread about an iPad 2 digitizer repair a few days ago saying that they can wake up the iPad with the home button but the power button actually works when you hold it to turn it off but the power button would not wake up the iPad.
Did anyone else see this post somewhere recently? Because I was going to post a solution to it which would be the power & volume flex cable not seated properly or damaged.
Ben さんによる
