Battery in fitbit flex
Does the fitbit flex battery ever need to be replaced?
I have had my Fitbit about 6 months and it will not light up? What do I need to do??
このアンサーは役に立ちましたか?
I charged mine last night. green light was FLASHING from back. Now there is no display!
Check my comment on the teardown… Fitbit Flexの分解
I think you can find a suitable 031012 battery if you look around & are willing to try dismantling it (which may destroy it).
このアンサーは役に立ちましたか?
So far no however the amount of sweat and gunk is awful. I clean my band every other day and clean the contacts carefully every few weeks.
このアンサーは役に立ちましたか?
Yes! I have had mine for about 19 months now and it only holds a charge for two days. Have not yet found out how to get the battery replaced.
このアンサーは役に立ちましたか?
==I have had my fitbit flex since Christmas eve and it takes hours to charge and wont hold a charge for even two days! Fitbit is going to get an angry e-mail shortly! ==
このアンサーは役に立ちましたか?
My flex is fully charged , all the lights are flashing but the screen on my iPad does not show any life. Have cleaned the terminals .
このアンサーは役に立ちましたか?
does battery ever need to be replaced ?
このアンサーは役に立ちましたか?
Yes... but Fitbit have made sure it is not possible. The Fitbit flex is basically a disposable item. Once the battery has died (mine lasted 31 months) it is time to bin it and try another brand.
The time on my FitBit won’t adjust to the proper time… How can I fix it?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 23
今までの合計 8,383
