How to change SSD?
Hello, sorry in advance for my bad english but i'm french guy.
Do you know how to change the SSD (& why not the RAM) on the Sony Vaio Duo 13 ?
Thanks a lot
この質問は役に立ちましたか?
Thanks a lot
この質問は役に立ちましたか?
I replaced the 128GB ssd with a crucial 240 ssd in a sony vaio duo 13 model svd13223. Here is a youtube slideshow of the order of disassembly. Be warned, as has been stated, the sticky mesh cover will not be reusable.
このアンサーは役に立ちましたか?
where did you buy the 240 ssd? Ive searched everywhere
crucial 240 ssd
Hello! Yuri,
Any update teardown photos for reference!!
THX!
Just got this page but in Chinese!! You can see the photos!!
このアンサーは役に立ちましたか?
It is not a hard job to disassemble this laptop. However you should note the it will cause unrecoverable damage to the sticker covering those screws. Your laptop will look ugly even if you manage to stick back. Plus, I have not see large SSD brands release M.2 SSD yet (Intel has one, but 180G only). If you have the SSD you want to replace, and you are sure you do not care about pealing off the sticker, I can teach you how to do that
このアンサーは役に立ちましたか?
Sorry to disappoint you, but as what I have said, this machine uses M.2 socket for SSD. The SSD you are thinking of has mSATA interface which does not fit the laptop.
Hi!
Can you give us detailed information how to open the Duo 13? I also want to change the ssd against a 480gb Crucial M500!
Hello Yuri!
Can you please tell us how to teardown the Duo 13?
Thanks a lot!
このアンサーは役に立ちましたか?
Like what I said, M500 does NOT fit this laptop!!!!
Please do read up about M.2 socket
このアンサーは役に立ちましたか?
このアンサーは役に立ちましたか?
OK, the socket is right.
'cause M500 got many versions, I didn't know which you are referring to.
But just a precaution, do you mind to have irrecoverable folds on your sticker covering the speakers?
If you don't, I will show you how to
このアンサーは役に立ちましたか?
That´s no problem for me! So please show me the way to change the ssd! Thank you!
このアンサーは役に立ちましたか?
Hello Yuri!
Thanks a lot!
このアンサーは役に立ちましたか?
Yuri, do you have the steps for opening the duo 13? Does anyone have a link for opening the duo 13 and replacing the ssd?
Thanks.
このアンサーは役に立ちましたか?
I am sorry to be very busy these days
Will do as soon as I finish my projects
Probably next weekend
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 9
過去 30 日: 28
今までの合計 24,498
2 件のコメント
No one ? pleeaasse
Killerofgta さんによる
RAM is soldered in
rachelle.black さんによる
