メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy NexusはGoogleの最新デバイスであるNEXUSモデルと同じグループです。HD Super AMOLEDディスプレイにカーブしたディスプレイ、そしてAndroidバージョンは4.0 Ice Cream Sandwichです。
How to fix broken screen myself?
I dropped my Verizon Galaxy Nexus (SCH-i515) and the screen's outer glass broke. The display itself and the digitizer (touch sensor) seem to work just fine. Is there a DIY method of replacing the broken glass? I've seen the part (the glass front panel) online for anywhere from $15 to $25, but I've also read that the glass and the digitizer are somehow glued together such that it's necessary to replace the whole display (around $150-200!).
Any advice/links/tips would be most appreciated, including a list of needed tools to get this done. I'd just buy a new phone, but I still have a year left on my contract!
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Chris, check the teardown on here. It will give you a basic idea about what you are up against. It will also show you the tools needed. Here is also a decent video. Yes, the screen is a display assembly and I suggest to replace the assembly, even so you can probably purchase the individual parts, but they are extremely difficult to separate. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Chris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 23
今までの合計 3,178
