How to repair a water softener?
Is there a repair manual for water softener? Our's is a PRO Series E E-70.
It just cycles won't turn on, release the water.
The incorrect regeneration cycle of your water softener might be caused by a number of factors. This includes an inadequate supply of electricity, a power outage that resulted in an incorrect setting of the clock, and a broken timer. Replace the damaged components to make the cycle functional once more.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 19
今までの合計 1,158
Crystal, that is a ProFlow SA-PRO-E 70? what cycles and what won't turn on?
oldturkey03 さんによる
The tank comes on and makes a lot of noise as if the water was cycling through ; however, it never stops and water never releases.
Crystal さんによる
Water pressure drops from time to time in the kitchen faucet or bathroom shower
osiomesiete さんによる
