1998 Mazda Protege Starter
Where is the starter and is there any helpful free guides??
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Brian, the starter is located between transmission and engine down intake manifold. Look for number 17 in the diagram
STARTER REMOVAL/INSTALLATION
Warning
• When the battery cables are connected, touching the vehicle body with starter terminal B will generate sparks. This can cause personal injury, fire, and damage to the electrical components. Always disconnect the battery before performing the following operation.
1. Disconnect the negative battery cable.
2. Remove the battery.
3. Remove the intake manifold bracket.
4. Remove in the order indicated in the table.
5. Install in the reverse order of removal.
このアンサーは役に立ちましたか?
Which engine is this for?
@mememachine what are you looking for?
Where does the plastic cap go onto? And the other part that's connected to the neg battery wire?
過去 24時間: 0
過去 7 日: 9
過去 30 日: 46
今までの合計 22,219
