メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
デュアルマイクと802.11ac Wi-Fi接続を搭載した、Apple製MacBook Airの中でより小型のモデルです。
Charging problem after spilled coffee.
Hi. I spilled about a half cup of coffee on my Macbook Air. As soon as it happened I turned it upside down and shut it off. After letting it sit for a while I turned it on and everything works fine except the charging. I have no light at all on the magsafe and the battery will not charge. When I plug it up it shows that's it's plugged in on the status bar and will run on the charger but the battery is not charging. I have cleaned the logic board and the DC board with alcohol and after putting it back together it's the same. I would really appreciate some advice I'm hoping it may be the DC board as I can't afford the logic board. I also didn't see any coffee or anything sticky on the logic board. Actually very little coffee got into it. Thank you for your time! Macbook Air mid 2013 11"
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I have the same problem except worse. It wont turn on at all and when I put the magnetized charger cable on there is no green or orange light.
Does this mean the problem could be irreversible?
Should I take to the Apple store and have them run diagnostics?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Check the function of all your keys to see if it needs a top case replacement. Your diagnosis sounds correct. Try replacing the magsafe board and see if it solves your problem.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Scott Bonnell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 737
