メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
締切られた回答
no image when I turn on laptop
when i press the power button on my MacBook pro, all i hear is the fan running for 2-3seconds then i hear a click and then the laptop just shuts off, i have been told that my Logic board is shot, not responding. if so i would like to get pricing on it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
You could unplug the HD cable and the Super drive cable from the logic board, reseat the keyboard ribbon cable and do the smc reset just for giggles.
I've seen several 2-3 second and shutdown issues caused by keyboard problems.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
thanks i'll try that
さんによる
コメントを追加
Well... I found some but the prices vary wildly. Here is a link to some on ebay. Good luck on those. As fas as what's actually causing the problem it sounds like it could be a faulty power supply. Is it possible that something is drawing too much power from the unit and causing it to trip? Wish I had a real answer for you, good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thanks i'm trying to stay away from ebay, you just never know what you are actually buying.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 76
