メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon D80は、2005年に一般発売された1,020万画素のデジタル一眼レフカメラです。デジタル写真の撮影や動画撮影を目的としています。
FULL message on LCD
I purchased a new Ultra SanDisk 64GB for an upcoming trip. I have formatted the disk, but the LCD on my D80 says "Full" and will not allow me to shoot. If I replace with the current 16 GB disk, everything works OK. What can I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
9 件のコメント
Did you format your new card?
さんによる
The following SD memory cards have been approved for use in the D80 digital SLR. All cards of the designated make and capacity can be used, regardless of speed."
Nikon 512MB, 1GB
SanDisk 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1, 4GB2
Panasonic 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1, 4GB2
Toshiba 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1
All SD memory cards indicated above can be used regardless of their transfer speed.
Lexar Media
256 MB, 512 MB, 1 GB
Platinum II (60x) series: 512 MB, 1 GB
Professional (133x) series: 1 GB, 2 GB1
1 If the memory card will be used with a card reader or other device, the device must support 2-GB SD memory cards.
2 SDHC-compliant.
from https://support.nikonusa.com/app/answers...
So according to Nikon, even your 16GB should not be working;-) try to format and see what you come up with.
さんによる
remove battery from camera and wait about 30 seconds then then replace and all should be ok
さんによる
Thanks @james cleary, it worked.
さんによる
I'm having the same problem, k have a SanDisk 64gb in my d80 and it's formatted to Fat32 and it still says full
さんによる
4件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
Max size of card is 32GB (SDHC)
read more at http://en.wikipedia.org/wiki/Secure_Digi...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
There is a good chance the camera doesn't recognize that large of an SD card. Did you try creating a smaller partition on the card? Nikon may have a firmware update but that's an older camera so it may not support that large of a memory card.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
How might one do that?
さんによる
How do I partition the SD Card?
さんによる
コメントを追加
回答を追加する
Joseph Sharkey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 46
今までの合計 26,611
