Returned system to Acer 3x now. still same problem.FREEZES. Win7 installed. added HDD inspector for HDD temp. removed HDD cover, 6"fan directly on system, unit raised 1.25" with plastic raiser.
this was to allow only 4 Auto updates. HDD temp 90*, this time all updates passed. next will attempt Office 2010 Pro Full install, with same method. normal install has failed 3 times.
Retired computer-elec tech. many thing to try... will keep posting back.
Snuffy
Today ran some tests. removed memory cover, removed hdd cover,using usb - started installation of Office-2010 Pro. monitored HDD temp, max - 102 no enough to kill. installation went 100%. replaced HDD cover & still again repair installation 100%. so far i see the backing over the memory cover does not allow heat removal. I'll remove the hard backing & replace with cloth...
1. It is 100% clean of Virus - guaranteed
2. power supply is quite big - no problem there
3. I use the WORK METHOD to test for FREEZE UP. insert a USB and either CLEAN install Office(full)SP1(1.21GB) or DL massive upgrades from MS... before removal of heat shield from MEMORY i could FREEZE very easy.. from 1983 to day 99% for me FREEZE is memory or CPU heat problem. test has been working CPU Memory and HDDs - hince UPDATE or DL at max - monitor is easy to see if working hard.
removal of cover - now can DL over 4GB max NoProblem, Installed Office 2010 - NoProblem, 1st time HDD ever went to 110* w/o freeze.
There are NO ACCESSORIES on this UNIT.
I think I have found the fix - open display and change to Win7 Basic.
a. Memtestx86 over 9 hrs - NO ERRORS
b. WD Diag HDD and ALL TESTS - PASS.
c. opened Display and changed theme to Win7 Basic .. No more errors, today. no fans used, plenty of heat... HDD temp over 112*, memory warm to touch. NO ERRORS...
Sounds normal. I finally disabled AERO. No Freeze up since.
Thanks to all the others whom have offered. Take the Battery out , changed PWR Supply, swapped memory swapped HDDS. the only thing I have to do is DISABLE AERO. then NO FREEZES but the sound is distorted.(I can live with that.)
19 件のコメント
Acer is the number one laptop i fix daily, so many of them go wrong. The flickering screen, nosey fans, random crashs. If you fix yours get rid of it quickly.
SPAM
fix computers さんによる 共有
I have an Acer Aspire One A0751h, 2BB RAM, 220 GB HD, running Vista Home Basic. I've been very disappointed with the frequent freezes since I bought it last year. I would have expected better from a major company like Acer. It's the last Acer product I will ever buy.
Philip Marshall さんによる 共有
Okay lets do it. lets make it a comment ;-)
oldturkey03 さんによる 共有
I switched my OS from Windows to ubuntu and have not had a problem at all.
Windows is known to be %@^@ on comps with small memory and/or ram capacities, if you don't know how or can't afford to change parts ubuntu is free, it takes a bit to learn how to use but I found it was well worth it.
Enari さんによる 共有
Mine, Acer ES1-711 Model: ZYL, is reproducible by any heavy video activity especially 100% failure with full screen. I don't get the sound. My previous laptop, AMD based, lasted 10 yrs on linux. This one is going to be chucked as I have found no solution in the last year. Disappointing. My guess is the atom chip which handles the video is the culprit.
fred roller さんによる 共有
14件以上のコメントを表示
