メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
How can I repair a keyboard?
Is there anything I can do to repair a keyboard,my logic board is fine after I've used it for months it even chimes after a restart,at the moment I use the on-screen keyboard and it doesn't start, I have to boot it from the back.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
That is a very expensive way to repair a keyboard on a MBP.
I would recommend following that guide but when you get to the point where all the components are removed (which are in the way of the keyboard) start carefully removing the backlight diffuser panel and the other plastic panels between the keyboard and backlight.
Next you have lot of screws to remove, takes about 15mins to remove them all. Once these are removed please don't forget about the power switch as that is attached to the keyboard. it is covered by a small metal plate held down by two screws, just remove them and you should be able to lift the power button out.
Thats it the keyboard is removed, these keyboards are readily available on eBay and do not cost much, much less than a whole top case anyway. Here is an example, UK eBay site http://www.ebay.co.uk/itm/Macbook-Pro-13...
If you need more help or a step by step please ask and I will be happy to help.
Cheers
Brendan Mills
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
That seems like a better idea. Based on the guide, I wasn't sure whether or not the keyboard could be removed.
さんによる
Yeah it can be removed just takes a little time removing approx 60 screws, maybe I will do a guide soon.
さんによる
コメントを追加
It looks as though the keyboard is attached to the upper case. You can use this guide to replace it. This is the part that you need.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Upper Caseの画像
製品
$49.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Gregor Jordaan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 13
今までの合計 265
