メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Please help me identify these two missing IC chips?
I was trying to fix my power button but instead I think I bricked my phone. I think while trying to pry out the battery I broke off two IC chips. Currently my phone keeps searching for a signal and also the power button doesn't seem to work but I'm sure the button is functioning and properly plugged in.
Please see the pics:
http://i.imgur.com/Su4YlXI.jpg?1
http://i.imgur.com/J43HqxU.jpg
http://i.imgur.com/0VnEeu3.jpg
I've searched online and it seems the top (right) is a U18_RF. Can anyone confirm this?
However I have no idea what the second (blue thing that looks like a resister) is. Can anyone help? Also where may I find these parts? Any good tips on how to resolder these on? I've done some some soldering before however just nothing this small and was wondering if there are any useful tips for tiny circuitry that I am unaware of. Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Heres a good pic showing the area of the components you damaged, sorry to say it doesn't offer much 4S Logic Bd.
さんによる
コメントを追加
4件の回答
ベストアンサー
yingwang01, you got the U18_RF right. U17_RF is a SASLE1G58AA0F57 IC. The other component is U18_RF is a logic gate 74AUP1G08GF SOT891 package available right here. Here is the datasheet. U17_RF is a LGA IC and both components will require SMD soldering. This will give you a broad idea of how to solder those components. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Oldturkey03! Wow you are just...amazing! I posted on here kinda expecting people to toss around suggestions. I NEVER thought I'd get the EXACT answer nor a diagram and links to purchase! Just wow! Thank you! :)))
さんによる
Also might I add, where might I find the U17_RF? Thanks!
さんによる
yingwang01, I'll be looking out for that one. I know I've found it once before :-) Thank you for accepting my answer.
さんによる
Thanks a lot Oldturkey03. I see how you got 92.5k points!
さんによる
コメントを追加
最も参考になった回答
Looks like your antenna is no longer plugged in ! Try to fix it. Mabe did you lose the antenna cable. You can own a new one @ iFixit store.
Tell ys if it worked !
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I'm pretty sure the antenna is plugged in. The open port you are probably looking at is empty. The antenna is actually under the small black clip to the bottom left of the battery. Thanks for keeping a sharp eye though :)
さんによる
コメントを追加
Im looking for big IC number which is near CPU IC in iphone 4 . Any body help me
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If you can post an image of the exact IC, yes we can help you.
さんによる
コメントを追加
Hello, how to buy the chip
U17_RF SASLE1G58AA0F57
and
U18_RF 74AUP1G08GF
many thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
yingwang01 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,731
