メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
無料の修理ガイドと高品質の交換部品と工具、iPhoneを自分で修理するために必要なものはすべて揃っています!最新のiPhone 17シリーズから2007年にリリースされた初代iPhone 2Gまで、iFixitには、すべてのiPhoneに対応する無料の修理ガイドと分解情報があります。
Hardware diagnostics service software
Hello,
I started a little bit trading with iPhones. Is there any way how can I make hardware check - diagnostics of problems by some software?
And what repair services use when they provide "diagnostics" service.
Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 16
3 件のコメント
my iphone 6 shut off just like that and now it only comes on when i plug the cable in, but this the logo come on and then cuts off. i started it up in dfu mode and restored it but its just saying error 4005. what should i do?
さんによる
My iPhone 6 Plus has problems, I try and touch the screen sometimes and it doesn’t work, and when I try to download something it shuts off the iPhone and restarts it and all the other iPhones dont have these problems, my iPhone has many more problems to
さんによる
@Robin Mason This topic is not what you want to ask.
さんによる
コメントを追加
4件の回答
ベストアンサー
radesek, here is my answer to a very similar question:" You could check on here and see if that will help you a bit. "It’s called the iPhone Configuration Utility, which allows you to examine logs from your iPhone or iPod Touch, to apply configuration and provisioning profiles, and more. The tool is very interesting!" from here I believe the software you are thinking of is called "Behavior Scan" More info about it on here and here. I would also like to recommend the iPhone Troubleshooting Guide compiled by one of the users on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Thank you, but I already read this information. The problem is, that I think iPhone Configuration Utility is not exactly what I am looking for and that Behavior Scan somehow cant be accesed without login of Apple employee right?
I need software that will test hardware things like working wifi, camera, jack and stuff like this. Is it possible?
さんによる
Can be this a sollution? Problem is I can not be sure with it, since my iphone does not have panicplist entry.
さんによる
I do not think that there is any diagnostic software that is available for an end user, that will tell you exactly what is wrong with the iPhone. That would be to easy;-) From what I've read if your phone shows panic.plist. then you may have a hardware error, not very descriptive.
さんによる
Where to look for that panic.plist file?
さんによる
is there any point having a website with all dead links
さんによる
1以上のコメントを表示
コメントを追加
Phone doctor plus in the app store, however contact the developer for business solution.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I'm using Battery Health - Your Battery Doctor app in the app store, very nice app
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello, my company uses NSYS tools. It’s quite easy to use and accessible.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
radesek さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 28
今までの合計 117,768
