メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amazonから発売されたKindle Fire7インチのタブレットの改良モデルで、1280x800 HDディスプレイを搭載しています。2012年9月に発売されました。このデバイスの修理は直接パーツにアクセスできます。
How Do I separate digitizer from LCD
My Kindle Fire HD 7" digitizer is cracked, but the lcd itself is perfectly fine. Touch and everything is still responsive and no loss of pixels. I purchased the digitizer separately, but upon dissasembly realized that the glass is connected to the lcd by adhesive. How do I separate the digitizer from the lcd without damaging the lcd in the process?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
7件の回答
最も参考になった回答
The short answer is you dont, replace the screen/digitiser/LCD as a complete unit.
It might look like replacing just the screen/digitiser would be cheaper but it wont be, its almost certain you will break the LCD if you try to separate them.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I separated it just fine. There are also tons of video with people separating with no problem. Don't heat the whole screen just the edges and once you get something in between don't let the glue adhere to the LCD screen again. Keep it seperated with plastic cards so you wont have to blast it with heat again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I'm guessing a heat gun, with lots of time and slow. I'm in the same situation lol
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've repaired around 200 Kindles since the first one came out. I've experimented with different techniques to get the two apart. Closest I came was pulling a guitar string (sixth string) between the two screens while constantly heating them. I did separate them but the problem is, the amount of heat needed to melt the glue is too much for the lcd surface to take without discoloring it. I really don't think it's possible.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi.i have same situation.is the way to begin from breaked screen glas out and after that replace with heater from display?
さんによる
Joe have you found a source for the HD10 SR87CV SCREEN? I'm searching for one and the ones I have found seem comparable to the price of a used unit.
さんによる
コメントを追加
My screen is cracked and part of the touch screen dont work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
why pay £40 ish pound for lcd & glass digitizer? they only cost £50 for a new one on amazon uk???
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i mean that is for a brand new kindle hd 7" £50
さんによる
コメントを追加
The thin glass digitizer on the HD10 is bonded to the entire surface of the LCD screen with a pretty strong adhesive. I thought I was breaking the edges loose with plastic spudgers and a heat gun but I left the top layer of LCD glass bonded to the digitizer. Without specialized equipment you will probably not separate the two layers successfully. Buy a replacement as a unit with both pieces already together. Other Amazon products are not designed like this. Others are glued only on the edges.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Juan Rodriguez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 5,483
