メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Apple 製の外付け光学ドライブです。本質的には MacBook Air SuperDrive を刷新したものです。
usb disc drive problems?
I wanted to run a game on my computer tonight but my computer is not picking up my disc! I cant eject my disc because it wont show on my screen! please help urgently answer would be much appreciated !
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
コメントを追加
10件の回答
ベストアンサー
Try restarting the system and press the C key to get it to read the disk which it will fail and kick out. Otherwise you'll need to open up the drive to pull the disk out. Click on the drive image to the right it will lead you to the iFixIt guide on how to open the drive up.
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
thank you so much!!! that really helped me!
さんによる 共有
@anon, if it helped, why the downvote? Downvotes are usually reserved for wrong a malicious answers :-)
さんによる 共有
the drive icon is not showing on computer? so its not opening?
さんによる 共有
Go under Finder, to the left of the Apple in the upper left hand corner to Preferences. Click on general > CDs DVDs, and iPods. See if the icons shows up on the desktop.
さんによる 共有
コメントを追加
to make the superdrive work on the Macs marked with No from the above listing:
From the Terminal app open a session locate & do the following
sudo pico /Library/Preferences/SystemConfiguration/com.apple.Boot.plist
enter your password"
this opens:'''
<?xml version=”1.0″ encoding=”UTF-8″?>
<!DOCTYPE plist PUBLIC “-//Apple//DTD PLIST 1.0//EN” “http://www.apple.com/DTDs/PropertyList-1...>
<plist version=”1.0″>
<dict>
<key>Kernel Flags</key>
<string></string>
</dict>
</plist>
now add mbasd=1 between the <string><string>
should look like this:
<dict>
<string>mbasd=1</string>
</dict>
</plist>
save and reboot
Two commands allow you to save the current text in Pico (for the novice) being edited. The CTRL-X and CTRL-O commands save the contents of the editor. The former command exits the editor after saving, while the latter command allows for continued editing after saving.
works on 10.8.5, should work from 10.6, works in 10.9.3, latest Maverics may 17 2014
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Worked for me on MacBook Pro 5,3 (Mid 2009) running OSX 10.6
Thanks so much!!!
さんによる 共有
can seem to get cursor to get me to enter mbsad=1 in between the string thread? it just defaults to the top of the code <?xml, etc..etc..
さんによる 共有
I followed the instructions, but didn't see how to save the edited file!
さんによる 共有
コメントを追加
This drive is only compatable with these machines:
http://support.apple.com/kb/HT5630
Apple Product Compatible
MacBook Air Computers
MacBook Air (11-inch and 13-inch, Mid 2012) Yes
MacBook Air (11-inch and 13-inch, Early 2012) Yes
MacBook Air (11-inch and 13-inch, Mid 2011) Yes
MacBook Air (11-inch and 13-inch, Late 2010) Yes
MacBook Air (Mid 2009) Yes
MacBook Air (Late 2008) Yes
MacBook Air Yes
MacBook Pro Computers
MacBook Pro (Retina, 15-inch, Early 2013)
Yes
MacBook Pro (Retina, 13-inch, Early 2013)
Yes
MacBook Pro (Retina, 13-inch, Late 2012)
Yes
MacBook Pro (Retina, Mid 2012) Yes
MacBook Pro (13-inch and 15-inch, Mid 2012) No
MacBook Pro (13-inch, 15-inch, and 17-inch, Late 2011) No
MacBook Pro (13-inch, 15-inch, and 17-inch, Early 2011) No
MacBook Pro (13-inch, 15-inch, and 17-inch, Mid 2010) No
MacBook Pro (13-inch, 15-inch, and 17-inch, Mid 2009) No
Mac mini Computers
Mac mini (Late 2012) Yes
Mac mini (Mid 2011) Yes
Mac mini (Mid 2010) Yes
Mac mini (Late 2009) Yes
Mac mini (Early 2009) Yes
Mac mini (Mid 2007) No
Mac mini (Intel) No
Mac mini No
iMac Computers
iMac (21.5-inch and 27-inch, Late 2012) Yes
iMac (21.5-inch, Late 2011) No
iMac (21.5-inch and 27-inch, Mid 2011) No
iMac (21.5-inch and 27-inch, Mid 2010) No
iMac (20-inch, Mid 2009) No
iMac (21.5-inch and 27-inch, Late 2009) No
iMac (Early 2009) No
iMac (24-inch, Early 2009) No
iMac (20-inch and 24-inch, Early 2008) No
iMac (20-inch and 24-inch, Mid 2007) No
Notes:
MacBook and MacPro computers are not compatible with either the Apple USB SuperDrive or the MacBook Air SuperDrive.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
it has been working up until now so i already have a compatible device
さんによる 共有
funny, we had the same thing happen in May with ours as well. It's not recognized on any machine tried it on 3 of them from the list.
さんによる 共有
I have been advised by Apple Care that the Apple USB SuperDrive will not work on any mac products newer than 2012.
さんによる 共有
Well Barb go to the link I posted directly from Apple and see for yourself. Who you going to believe? Apple or Apple Care or me?
さんによる 共有
コメントを追加
You have to write
mbasd=1
between <string></string>
so it's gonna be like
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have this :
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1...>
<plist version="1.0">
<dict>
<key>Kernel</key>
<string>mach_kernel</string>
<string></string>
</dict>
</plist>
So where should I type the code ??? I am really bad at it stuff and it is already a miracle that I have found where I have to type the code so please help !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Do the previous instructions not cause a problem with kext signing in the more recent versions of OS X e.g. 10.10.3 where Apple's restrictions mean that any unauthorised kernel edits are blocked and the system will inevitably fail to boot? i.e. is the 'hack' still current?
Sorry, last poster / anon but without this info it would be possible to follow these instructions and screw up the system for the sake of a Superdrive.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Yes! Good point. If you altered the file you will have an issue with Yosemite as kext files now need to be signed. Which is a good thing! Except when you hack the OS to make something work :-{
さんによる 共有
I have tested this command with Mac OS X.12 (Sierra), the latest Mac OS X so far. It works. Just edit the file and you should be able to use the drive :
Thanks.
さんによる 共有
I've tried modifying this file but system doesn't let me save with same name in Terminal. I've disabled System Integrity Protection (SIP) but I still can't save this file. Any suggestions. I have Sierra OS and MacBook Pro12,1 13" Retina Display. Superdrive works if I reboot my Mac, but not if I just connect it. Always has to be rebooted to fully function.
さんによる 共有
Same problem here with 10.12.6. It won't let me save the edited file.
さんによる 共有
コメントを追加
i connect my usb super drive with my macbook air but it does not show on my screen and don't know how to work. not showing any options.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i am experiencing the same thing
さんによる 共有
コメントを追加
Hi there,
Thanks.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
With 10.12.6 Iʻm having trouble saving the file after editing. It is accepting my passwords ok but the failure occurs with the Save.
Pico tells me:
"Error writing /Library/Preferences/SystemConfiguration/com.apple.Boot.plist"
I tried also with BBedit and when I try to Save it errors out with:
"This file could not be opened for writing, probably because it is in use by another application (MacOS Error code: -54)"
さんによる 共有
コメントを追加
The is ridiculous! Is there any explanation of *why* Apple decided to do this? If they didn't, they might actually *gasp* sell *more* of the "Superdrives" (how many people remember that as a drive that could handle 400K, 800K, *and* 1.4MB disks?)? Okay, probably not, since the Apple one probably costs at least 20% more than a comparable drive.. But still..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
High Sierra:
Boot in Safe mode. Then open Terminal and disable SIP
csrutil disable
Then type:
add value “mbasd=1” to string <string></string>
at end it need to look like this:
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1...>
<dict>
</dict>
</plist>
Save plist CTRL+O hit Enter and then CTRL+X
Enable SIP
csrutil enable
and reboot in normal mode
Why Apple dissable External DVD/CD Roms i don’t cnow - i think this is stupid and without a reason…
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
got : “ csrutil: failed to modify system integrity configuration. This tool need to be executed from the Recovery OS”
さんによる 共有
コメントを追加
回答を追加する
anon さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 95
今までの合計 62,065
