メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
MacBook does not work on AC power
MacBook stopped charging the battery and will not work with AC power adapter only.
MacBook notices the connected power adapter, but reports battery not charging. Adapter light stays green even when battery needs recharging. MacBook runs fine on battery power. Installed battery update 1.4. Checked the battery (Cycles 66, Condition: good; does charge on onther MacBook). Checked the AC adapter (works fine on other MacBook).
Logic board failure?
Any other thoughts?
Update
got no applecare for this MacBook.
read somewhere a faulty connector could be covered by legal product warranty (production fault)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Since it works with the battery and not the adapter probably the magsafe board is bad. I'm including the url's for the repair and the part. Ralph
MacBook Core 2 Duo Magsafe Board Replacement
MacBook MagSafe DC-In Board
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Agreed. + I would also try using some contact cleaner on any corroded surface.
さんによる
コメントを追加
最も参考になった回答
Power flows from the AC adapter, to the DC-in board, through the logic board and battery connector, then finally to the battery. There obviously isn't anything wrong with the battery or the AC adapter because they work on a known good machine. Therefore, it is something internal.
I would suggest opening the computer and checking the battery connector first. There have been a quite a few computers I have worked on and there was some corrosion in between the battery connector and the logic board. If there is then you need to replace the logic board and then battery connector.
Hopefully there isn't any corrosion and you can just replace the DC-in board.
Goodluck!
MacBook MagSafe DC-In Boardの画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
follow up:
re Jethro:
- is the DC-in board (only) a connector, or does it contain electronics ?
- visual inspection of the battery connector shows no corrosion.
re Ralph:
- if the DC-in board is a connector only, I find it hard to believe this can malfunction.
- if so, can a claim for repair be covered by an (extended) applecare warranty ?
MacRuud
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If you still have AppleCare and it hasn't gotten wet, take it in. Come back here after the warranty has expired.
さんによる
コメントを追加
回答を追加する
MacRuud さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 2,670
