メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2006年発売、モデル番号E1705で識別
video card not working need help locating same
video card does not work, it is built into the motherboard, or is it? Mine does not have a big video card as displayed in your pictures. There is a small green card plugged into the motherboard where it would appear the one you removed in the pictures. Is this little green card the actual video card ?
I have taken pictures if that helps.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Michael Crawford, that is a depends. "A removable (or discrete) video card is optional and present only if ordered by the customer. Standard video is integrated on the system board and is not customer removable." Download the service manual from here. It will help you to disassemble your computer, explain the parts to you, that way you will know what you have. you'll also find an excellent write-up on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michael Crawford さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 396
