How can I fix my VGA problem?
Mostly when ever i power on there is no display of dell monogram but screen is on
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here is a link for downloading the service manual for your computer. Good luck.
このアンサーは役に立ちましたか?
First try using it with an external monitor by connecting via VGA cable, if it works fine in such way then the problem is surely with your LCD connecting cable. However you can first try to locate if there is any lose contact of on board connectors which shall might help.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 2
過去 30 日: 8
今までの合計 887
1件のコメント
How do you know that the screen is on? what do you see when it is not displaying the "dell monogram" What OS are you using and what have you tried to fix it?
oldturkey03 さんによる 共有
