message pop up phone memory low
have nokia n8 with 16gb memory. Some time error message pop up that phone memory low, please delete some data. Just wanted to know that how phone memory can be increased from cell memory.
RK Sharma, seems to be a common complaint about this phone. Check the forums on here. Looks like a lot of unhappy people. Best way of getting some more memory is by restoring. Just remember to back up all of your data since a restore will delete it of your phone. Once you restored your phone, set the preference for your mail and txt messages to drive e: Again this may gain some space for you. Ultimately it looks likely the N8 has memory management issues. Hope this helps, good luck.
このアンサーは役に立ちましたか?
The "sent mail" folder contains copies of all the photos that have been emailed - this is what is taking up the memory. Delete the contents of that folder and you will get your space back. Believe me, I've tried everything else. As of 8/2014, I'm still using my n8, with no more memory issues.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 5,846
