メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Chromebook XE303C12-A01USは、11.6インチの画面と16 GBのSSDハードドライブを搭載したノートパソコンです。この小型ノートパソコンは、インターネットへのアクセスが容易で、さまざまなウェブアプリを実行できます。
Is it possible to replace the screen?
My chromebook screen is broken, it's got a massive black spot (1" across) and the screen is covered in random lines. I can only assume it took a hit but the case is undamaged. Any idea if it would be possible to replace, and if so where I could get the replacement screen?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 34
8 件のコメント
Just out of curiosity, have you checked to see if you get this done under warranty? It is a pretty new device and I am sure it should still be covered.
さんによる 共有
how would you know if it was under warranty
さんによる 共有
I have the exact same problem mines about 2 years old and i use it pretty frequently
さんによる 共有
I just did this. Took all of five minutes. Bought screen from Amazon for $37. Really easy.
さんによる 共有
Check out screensurgeons.com for videos that will step you through the process. Quick and easy.
さんによる 共有
3件以上のコメントを表示
コメントを追加
5件の回答
ベストアンサー
Hello,
I was searching to replace the panel with a better one, and I found a video on youtube:
http://www.youtube.com/watch?v=_mgyuVTTh...
It is made by some guys who also sell the panel.
The panel datasheet is available on the Internet, though (just google it).
Jacobo
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
These screens can easily be found on eBay and Amazon.
For the US Chromebook for example, I searched for the model number and LCD replacement like this "XE303C12 LCD replacement" on the Google. Found a new screen with Prime shipping on Amazon for about $45.00 US.
Install was as described in the other answer, but I did run into a small amount of adhesive tape on the bottom of my already broken screen and the bezel. I was not to worried about it but it took a little more force than I expected to get the bezel removed.
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
yessss i saw that and thats what i am going to do . Good in fo thanks
さんによる 共有
Thanks i now get another but it costs $60 yep --> $60 <--
さんによる 共有
コメントを追加
I work for a school and we have about 120 of these. The kids break the screens all the time so I've replaced about 20 of them. Its super easy, follow the youtube video above and order the screens from Amazon. The only things to be careful for: (1) cheap replacement screens can are just that; cheap. I have learned the hard way to only buy from VIV tech as I have been burned with crappy screen that don't fit right from other companies. (2) take a look at your old screen before buying. Some Samsung replacement screens have side mounting brackets and others have top mounting brackets. Make sure you order the one that fits yours.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
What is VIV tech - the only references I found had nothing to do with dealing in parts for Chromebooks and laptops Thanks
さんによる 共有
コメントを追加
No its not under warranty unless you paid extra. Mine is 45 days old and was sent to a HP Centers . 260 ..00s . It s a design flaw and should of been under warranty as i had lines going across first then by inspection it around the edges it cracked .
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
They are sending it back to me
さんによる 共有
so i can fix it for less .
さんによる 共有
i have broke my screen how much would it be to repair the screen for a chromebook samsung
さんによる 共有
コメントを追加
I found the Samsung warranty to be worthless. They falsely claimed water damage, but I bought it in a dry, sealed box, and it was never near water. Fortunately, Wal-Mart's extended warranty fixed it, even though the Samsung warranty should have. My LAST Samsung product!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
George Martin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 31
今までの合計 63,302
