alternating red lights flashing
Think I need re-set procedure for 1400 I have the re-set procedure for my 1280
Pat DIACCA Topp , try this:"
Download the Epson 1400 from here.
Unzip the file. Run the Adjustment Program for Epson Stylus Photo 1400 printer. Select the right port for usb. The port should be selected in Auto Selection. Click Particular adjustment mode.
Point on Waste Ink Pad Counter and press Ok.
Press Check Button to check the Waste Ink Pad Counter.
Click Initialization to reset.
Turn off the printer and turn it on again.
このアンサーは役に立ちましたか?
please repost the link to download from. thanks
このアンサーは役に立ちましたか?
Lynn, don't you know how to Google? Please put a little effort into finding the answers you need so you will not always be at the mercy of the selflessness of others.
hello
I have got epson 1400 . power is off and paper and ink lights are flashing . please help
このアンサーは役に立ちましたか?
hi my printer(1400) won't print anything whenever I try to print it stacks and then two lights starts blinking on the computer it's saying fetal error paper jam please help me
過去 24時間: 0
過去 7 日: 1
過去 30 日: 27
今までの合計 6,132
