メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
20回答 すべてを表示
iPhone 4 is working but screen is black?
Yesterday I dropped my phone, and it was working fine when I picked it up to check it, but a few minutes later the screen went black. I know it was still working, because I was still receiving phone calls, texts, and mail. I even took a picture with it.
I've tried holding the home and lock button. I also tried holding the lock button while constantly pressing the home button, but I think the problem with this is that my home button barely worked before the drop. I've tried to reset it and put it in DFU mode, but nothing is working. :( Note that I can't take it to the shop because it's jailbroken.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 104
34 件のコメント
Same thing has happened to mine so I restored it and my screen is still black and I can still hear everything. What do I do?
さんによる
My home button doesnt work!
please help me asap! :(
what can i do to get my phone back on track!
さんによる
Same happened to me but with iphone 5c and only about .75 of the screen :(
さんによる
My iphone screen is black, it turns on screen still black makes sounds I have done the following and nothing is working still:
Hard reset, took off the back and held down both top and bottom buttons.
さんによる
I just got my screen replaced (they tried two different screens) and this did the same thing, except the screen flashes back on when I take a screen shot. Which means the screen has the ability to work but something's not right...
さんによる
29件以上のコメントを表示
コメントを追加
25件の回答
ベストアンサー
You may have bumped the LCD connector off in the drop. Removing the rear glass is easy, and you won't have to do anything fiddly like removing screws inside the phone. You'll need a pentalobe screwdriver to remove the back, but that's it. Follow the Display Assembly Replacement guide and skip to the step that shows the LCD connector. The LCD connector should be second from the left. (The digitizer is on top of it.) Just give it a good push to seat it back in place and then retest your phone.
このアンサーは役に立ちましたか?
スコア 42
24 件のコメント:
Worked for me taking the back off then the black plate at the top of the phone and pushed all the visible connectors down one clicked and hay presto the phone now works :)
Thanks very much saved me a fortune
My daughters iPhone 4 was working but the screen was just black!
さんによる
as suggested previously,just took back plate off and pushed everything down a few times, and it worked! Thanks so much for advice.
さんによる
Your option worked for me. For people not having the right screw driver. Use a nail to take button screws of.
さんによる
thanks alot i also have the same problem i thought it was totally broked down,still i can feel the vibration of my phone and i can also here its sounds,the thing is its all blacked out!..iv read your threads on how to fix it,totally works! thanks for all the suggestion it may sure help other users with the same problem..more powers thanks a lot!
さんによる
My screen turned black too!
Also my home button is not working!
What should i do?
さんによる
19件以上のコメントを表示
コメントを追加
最も参考になった回答
Don't panic at all. If the screen is black, but you can still hear sound and the phone still works, just do this:
Hold down the home and lock buttons at the same time for 10-15 seconds and you'll see the Apple logo. This will work 100%—unless there is something seriously wrong. I hope I've helped!
このアンサーは役に立ちましたか?
スコア 129
148 件のコメント:
Dan that worked for me. thank you
さんによる
Thanks a ton.. holding it for 10-15 seconds works !!
Regards
Akkum
さんによる
This happened to me and holding the top and bottom buttons together worked I had new screen by a cheap repair shop and its never been the same since. Need new phone nut at least it works now
さんによる
i got the same issues and by holding home and lock button togather it comes back.
thnx maryann
さんによる
I tried the home and lock button solution- it worked! I'm very happy.
Thank you
さんによる
143件以上のコメントを表示
コメントを追加
just put it upside down and give a smack on its back and it will work
このアンサーは役に立ちましたか?
スコア 7
10 件のコメント:
Thank you I did that & it was working again once I restarted :)
さんによる
just put it upside down give a smack on its back and it will be ok
さんによる
January 11 by rafay mir
Above suggestion worked perfectly for my Sony Xperia Z1 . One tight smack and it came to life
さんによる
yup this works and my phone has come to life again
さんによる
Brilliant tip! Worked a treat-chuffed :)
さんによる
5件以上のコメントを表示
コメントを追加
Quick Solution:
My iPhone is the same, i can here that its working and can use Siri to text and make all my calls, but the screen is completely black until it randomly came back one day. Now the same issue has happened again this is the 3rd time actually but I've figured out a way which fixes it instantly...
Just hold the home button and tell Siri to turn up your screen brightness and its back!
Only works for Iphone 4+ you may also need IOS7. So connect to computer and update then try again. Hope this has helped some of you.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
when my iPhone is black screen and working the sound. when I hold power botton and home bottom and I say tell siri turn up your screen brightness it work now I can see may application and other thank you very much for posting that
さんによる
my iphone screen is black and ive got it on charge and thats doing nothing... i can still hear siri and ive told her to put the brightness but and she said"thats as highas it goes".what do i do....because my lock botton doesnt work.
さんによる
I told siri to turn up my screen brightness and siri says calling 201934
is it my siri or does everyones do that
さんによる
コメントを追加
1.Hold the Power button for 3 seconds
2.Hold the Home button without releasing the Power button for 10 seconds
3.Then the Apple Logo appears, and everything works as usual
First hold power button for 3 sec and dont relase it! and after 3 sec hold power and home buttons for 10 sec.
For 5 sec u must see Apple logo. If u dont see the Apple logo try go to the specialist. If u see Enjoy working i phone5!
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
I tried your solution but it didn't work. My apple logo flashes up but nothing else. Please help me have only had phone for 1 year, don t expect to have to get rid of it now. : (
さんによる
thank you so much. its help me a lot.
さんによる
yes thank you so much i was going to peru in a few days and i was freaking out!!!!!!!!!!!!!! glasias
さんによる
コメントを追加
This will sound absolutely ridiculous, trust me I thought it was. My daughter tried everything she could find online & had given up a week prior to me fixing the issue clean debris, hold power button & home button, different charging ports ,etc. .. I literally switched her vibrate button on the side back & forth a couple of times & the phone began charging right up .
It won't fix everyone's but it can't hurt to try. I still can hardly believe it was that simple.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
thanks this worked for me I cant believe its that simple
さんによる
コメントを追加
Even I too had a problem of screen blank, however, all the functions were working but no display.
Remedy was held the lock & button for few seconds and it became ok.
The problem was,it was gone to sleep mode due to too many applications were open.
To close the many applications, just click two times of home button and swipe upward all the applications. thats it.
Regards
rgk
9379190171
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Same problem with my wife's phone. Happened 3 times. The screen was black but I knew it was still on when I plugged it in and heard a charging sound. Just gave her a call and the screen turned back on like a charm.
さんによる
コメントを追加
If you cannot hard restart due to faulty buttons just disconnect and reconnect the battery if screen is still black then it's either screen is not connected correctly or it's faulty
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you so much. Worked for me. I have defective home button. And find my Iphone setting is on so I can't restore it thru computer. My battery is 100% and I dont want to wait days. So I cant try anything else but this. And my phone back to life. :D :* :))))) Again, Thank you soooooooooooooooooooooo much!
さんによる
コメントを追加
I tried the home and lock button solution- it worked! Thank you. Lionel
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
thanks for giving this suggestion it really works.. thanks
さんによる
コメントを追加
I need help with my no phone 4 bad
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My iPhone 4 turned black and I can still hear it and I tried the home button and power button but it did not work at all and I let it sit for a day on my tv and I tried to turn it back on but it still did not work at all.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
my iPhone 4 is kinda weird. the screen is black, and has some blue, red, orange lines on it. when someone calls, it rings. i even remember my password (where the numbers are located on the screen) I can hear the sound. I have tried the suggestions but i still cant see any apple logo :(
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Thanks my iphone4 was blackout and didn't work, when i rang to it from other phone ring is going but not reaching at my iphone4. I did the same by pressing the 2 buttons and it worked. Thanks
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My phone doesn't worked I tried the home and button and the on button but it didnt work what should i do my phone was wet from my bag being wet and it went off after that i tried charging it or putting it on the rice for 24 hours and 9 hours and charging it again but still nothing and then I tried Ur method of the button thingy but it dint work what SHOULD I DO PLEASE REPLY QUICK ANYONE
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Samee :( idk what to do , you got solutions ?
さんによる
コメントを追加
Just hold the home button and the power button for 15 sec and then the apple logo will show up like in 5 sec or more but the logo stays there for a while then it starts working
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I tried other things but they didn't work until this
さんによる
Thank you! Nothing worked until this!!
さんによる
コメントを追加
Even though it is jailbroken, Apple still has to service it for any hardware issues. If you can reseat the LCD and digitizer cable, that may fix the issue. Otherwise it probably needs a new screen assembly. While you're at it, might as well fix the home button too while you're down there. But if it's in warranty, Apple should replace it for free unless it is clearly physically damaged.
Pat
iFix SB
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You can check the internal connectors beneath EMI shield if they are properly connected or not. If not they you may need to order a new replacement screen and replace it by watching some online YouTube tutorials.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
David - I think adding anything here is a bit of a waste look how old the Question is and the level score the answer from Polly has. Clearly its the more logical.
さんによる
コメントを追加
Holding the home button down and lock screen button for ages worked for me! had to do it twice, but its good now
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
take down the screen to see whethere the cable is broken or get loose.
if not . maybe the screen is broken.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I take the battery out blow the inside and put the battery back in. An easy way to fix the screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This same thing happened to me and none of these options work so I took the back off and took the battery and display connectors off then plugged it back in and it turned on. if you have questions text me at 513-815-8107
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
[*** SOLUTION ***]
i was having the same problem, but i get my iphone screen lightening once again
all you have to do is just
  • Press/Hold is HOME button and POWER/LOCK (on/off) button for 10-15 seconds, you'll get the iphone RESTART,
the apple logo will appear, i hope it helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have both the lock button and the home button ruined ,and the same problem. what do I do?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
mine ran out of battery and came back just check on itune's by pluging it in check in iphone settings really quickly then unplug it i should show up and when it runs out press home button you should see no power
screen so just plug it up and ta-DA there you go
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have a iPhone 4 which worked fine till old battery went I put new battery in the phone but it now won't work what can I do to get it to work help me ASAP
さんによる
コメントを追加
POSTED: 01/09/2017 OPTIONS
[ SOLUTION ]
I was having the same problem, but i get my iphone screen lightening once again
Regards
Shrawan Kr Sharma
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
linda さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 43
今までの合計 457,746
